help
Old Jul 4, 2005 | 01:59 AM
iceman7329's Avatar
iceman7329
help
just installed compass and temp. gauge in 04 X 5.4 V-8 and it plugs right in but wont work got it new from ford and they said they dont knw why it wont work can any one help me.
Old Jul 5, 2005 | 12:21 AM
PatsPOS's Avatar
PatsPOS
Well, you're probably not gonna like this much, but you're probably gonna want to buy an EVTM (Electrical/Vacuum Troubleshooting Manual) from Ford and a test light or multimeter. The problem might be something as simple as no power into the plug, or maybe since your X didn't originally come with the compass and thermometer, it might not have the necessary sensors. Just about every Ford built with A/C since the early '70s has had an ambient temperature sensor (although that doesn't guarantee that signal works for the temp display on the overhead), but I have no idea where the compass sensor might be.
I'm sorry for not offering a solution, but hopefully I've pointed you in the right direction to find the problem.
Pat
Old Jul 5, 2005 | 02:18 AM
iceman7329's Avatar
iceman7329
thanx for the info im going to see if there is power to the wires thanx
Old Aug 4, 2005 | 05:55 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 4, 2005 | 09:23 PM
V X's Avatar
V X
i know in the 02 owners manual there is a procedure that involves driving slowly in circles to "orient" the compass should it need calibrating. maybe yours needs calibrating?
