Sponsored by: Auxito
1997 4.2L Engine Knock
Old Aug 4, 2005 | 07:30 AM
dominic's Avatar
dominic
Question 1997 4.2L Engine Knock
Hi all,
I have a 1997 F150 w/ 4.2L V6. 86k miles. My truck was driven home w/ no problems. A day or 2 later I went to start it and I got the dead battery click click. I was leaving for vacation so a week later I got a new battery. When I installed it and hit the key the starter turned w/ a loud clunking metal mess sound. I then replaced the starter. The starter was missing about 3 teath, but the flywheel looked fine.
I hoped this was it. Upon trying to start the motor wouldn't spin. After pulling plugs I found liquid in a couple of cylinders. I don't think it was antifreeze, but can not be for sure. Anyway I cleaned out liquid, and installed new plugs. W/ all plugs out the motor turned over fine. W/ new plugs in I started the engine and it makes a loud knocking sound toward the bottom back of the motor. The tranny sounds quiet.
Guessing something cracked/broke bad bearing/piston/rod etc.? Not sure. Can't get oil pan down w/o taking engine out.... Oil doesn't appear to have water in it and it is full of oil.
Anyone seen this? Truck has been run easy and I can think of no reason for this....low miles etc.... Any Help???
Thanks
Old Aug 4, 2005 | 07:37 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 4, 2005 | 07:54 AM
WVF150VIANC's Avatar
WVF150VIANC
Originally Posted by dominic
Hi all,
Thanks
dominic, sounds like you are a victim of the 97-98 4.2 lower intake gasket leak, which leads to hydrolock. You most likely have bent a rod. Do a search in the 4.2 forum for related threads. You'll find plenty.
Rich
Old Sep 5, 2005 | 03:35 PM
FordFrenzy97's Avatar
FordFrenzy97
yep same thing happened to me had to buy new motor 4.2's are notorious for this.
98F150on33s
1997 - 2003 F150
Nov 26, 2014 11:28 AM
LaReko
1997 - 2003 F150
Jun 20, 2012 09:35 PM
carmag99
3.8 & 4.2L V6
Mar 22, 2009 04:43 AM
manelady
Electrical Systems/Wiring
Sep 1, 2008 01:09 PM
shotgun sam
3.8 & 4.2L V6
Jun 4, 2006 06:56 PM
