Hi there guys
Old Aug 4, 2005 | 12:52 AM
macek's Avatar
macek
Hi there guys
I'm new here ,have question about my 99 7.3 power stroke .I have oil leak just from the pan behind oil pan and transmission . Where do I find specs for the seal between engine and trany? Thanx for suggestions
Old Aug 4, 2005 | 02:15 AM
RedStroker6's Avatar
RedStroker6
I can't really help ya other than offer this site that mighthave some info for ya http://www.nav-international.com.br/...rStroke/hs.asp
also, WELCOME! this site is awesome. i know someone will be along here shortly (maybe in the mornin, its gettin late) with some more answers for ya hopefully. good luck, enjoy the forum, its a great resource and a GREAT bunch of folks here.
Old Aug 4, 2005 | 05:46 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
.YES..Welcome Macek, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 4, 2005 | 08:13 AM
HeatStroked's Avatar
HeatStroked
99% of the time it's NOT a rear main seal.
Check the top of the engine, in the valley and you will find oil or fuel.
You have a leak from one of the following;
1. Loose intercooler boots.
2. Pedestal "O" rings are bad.
3. EBPV actuator arm "O" ring is bad.
4. Bad "O" rings where the lines connect to the HPOP.
5. Oil galley plug(s) loose and/or bad "O" ring.
6. Fuel regulator "O" ring(s) are bad.
There is a passage at the top of the valley that allows oil or fuel to run down the top and side of the tranny and leak out the inspection cover between the oil pan and tranny.
Clean the valley and check where your leak is originating.
Old Aug 4, 2005 | 11:21 AM
cookie88's Avatar
cookie88
FTE Emeritus
I fully agree.
It can be difficult to see into the engine valley if you don't know what you're looking for. A good stong flashlight and removing the intercooler tubes will help you get a better look at the situation. Also, pull the plastic "powerstroke" engine cover off and you can get a good look behind the high pressure pump and around the fuel filter.
