PCM code 0603
Old Aug 3, 2005 | 07:31 PM
clintbonnie's Avatar
clintbonnie
PCM code 0603
Can anyone tell me what would cause a fault code 0603, (PCM keep alive memory error) on a 99 PSD. I reset it but it comes right back when I drive it. Does not cause "check engine light" to come on. Truck runs fine.. Any ideas..?
Old Aug 4, 2005 | 12:29 AM
wlihntr's Avatar
wlihntr
i think thats one of the codes that will be set if you have a chip or programmer, if you have one it should be fine, (sorry, i am to tired to look it up to be sure)
Old Aug 4, 2005 | 11:32 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yep. Anytime you disrupt the power supply that code will be set. Installing a programmer, unhooking the batteries, etc. Not generally anything you have to worry about.
If it comes back everytime you drive it you may have a blown fuse or something of that nature.
