Engine/tranny Angle
Old Aug 3, 2005 | 08:02 PM
62 red truck's Avatar
62 red truck
Question Engine/tranny Angle
I bolted the eng and tranny in today.It's a 62 with a 4.6 and IFS from an 04 Crown Vic.I'm reworking the tranny cross member and I realized I don't know what the h--- I'm doing. How do you measure the angle of the engine?What is the angle suspose to be?If I raise or lower the tranny brace I change the angle.
The rearend is not installed.I bought a round angle gauge but where do you put it? HELP PLEASE!!!!!! THANK YOU Larry
Old Aug 3, 2005 | 10:13 PM
BobbyFord's Avatar
BobbyFord
This link will give you a picture that might help you out. Click on this link.
To correctly do this the suspension should be "loaded".
http://www.iedls.com/ptsetup.html
Old Aug 4, 2005 | 04:25 AM
Hoopdie's Avatar
Hoopdie
Awesome link, instig8tr63 !!!
Maybe now I'll get some of those vibrations out of my truck.
Love this board!!
Old Aug 4, 2005 | 09:09 AM
FordBoypete's Avatar
FordBoypete
Unhappy
There's a page right here on FTE also, about Drive Line Phasing. I think the address is:
http://www.clubfte.com/users/jniolon...nephasing.html [if I got it right]. I won't know until I send this & try the link I guess.
Well it does not work through this sites' "security" and monitoring system.
When I fwd the address it deletes several characters in 2nd drivelinephasing & replaces them with periods [ ..... ] instead. Too bad because the page is here on FTE which "protects us" from using it with it's security programs and monitoring practices.
Retype address above into true search engine like Yahoo or google, then you can get to page on Drive Line Phasing posted right here on FTE.
How dumb is that?
FBp
Old Aug 4, 2005 | 06:52 PM
62 red truck
Thank You,instig8r63 excellent site.
Thank You FBp,tried the address on YAHOO but would not come up.I put in www.clubfte.com and it came up under DRIVE LINE PHASING.Address is http://jniolon.clubfte.com/driveline...nephasing.html Thank you so very much.These should be required reading for any one doing engine or rear end swaps
Larry
Old Aug 4, 2005 | 08:32 PM
62 red truck
wow it left part of address out and screwed it up.just use the www.clubfte.com
