302 hunts at speed
Old Aug 3, 2005 | 05:37 PM
72earl302's Avatar
72earl302
302 hunts at speed
my f-100 302 has been hunting at speed. It usually happens when you accelerate quickly to 60 and then keep on it. It feels like the fuel pump isn't feeding it enough fuel at sustained higher rpms. I figured the electric fuel pump i put on it just wasn't cutting it at passing speeds so i continued to drive it, but now its doing it when you accelerate quickly from like 35 to 45.
thanks in advance for the help
BB
Old Aug 4, 2005 | 09:58 AM
Kemicalburns's Avatar
Kemicalburns
how many miles on the motor. could be a worn or slipping timing chain. if you pull the dizzy cap and have someone turn the motor over by hand and you watch the rotor turn see how far you can go before it moves.
if it is fuel related whats the fuel pressure and is this efi or carb?
Old Aug 11, 2005 | 12:05 PM
72earl302's Avatar
72earl302
sorry about the delay on the reply, i've been on vacation. the cam, timing chain, and gearset are brand new. the engine has an edelbrock performer 600cfm carb, I bought the fuel pump from a local parts store and they said it ought to pump plenty of gas for my engine but it didn't have specific gph on the fuel pump. When I drive it and it starts to hunt you can let it coast for a little bit and then it will run normally unless you get on it hard. that's why it sounded fuel related to me.
Old Aug 11, 2005 | 07:26 PM
TigerDan's Avatar
TigerDan
It sounds as if you could be right. It may be that the fuel pump simply doesn't have enough output, or it could be defective. My local Napa store has had a lot of returns of a small, round plastic-encased fuel pump, I think it's called a Jewel or something like that. You didn't get one of those, did you?
Old Aug 13, 2005 | 04:26 PM
72earl302's Avatar
72earl302
the one I got was an round inline one with a brass case, does anyone know how many gph a 302 with a 600 cfm carb and a comp cams 268H cam might use?
Old Aug 13, 2005 | 04:57 PM
TigerDan's Avatar
TigerDan
Okay, I'm just guesstimating here, but I would say somewhere in the vicinty of 70 GPH.
mbaquet
2004 - 2008 F150
17
Nov 15, 2016 01:01 AM
swartzad
Nov 6, 2014 04:33 PM
riverratba
1983 - 2012 Ranger & B-Series
33
Dec 10, 2007 09:12 PM
fishtail
Mar 8, 2005 11:48 PM
3eggOmelet
13
Dec 16, 2003 04:33 PM
