Aerostar Ford Aerostar
O2 Sensor help
Old Aug 3, 2005 | 09:39 AM
aerostar90's Avatar
aerostar90
Question O2 Sensor help
I am having a problem taking the o2 sensor off. I think it is the original one. Are they reverse thread or regular. And idea's how to get it off? Thanks.
Ken
Old Aug 3, 2005 | 09:49 AM
96_4wdr's Avatar
96_4wdr
6 point socket or special O2 sensor socket that some auto parts stores will loan with purchase of O2. 6 point box end wrench may work also.
some have had to resort to pipe wrench because of clearance issues
soak overnight with good penetrating oil, spray 2 or three times and let it soak
Old Aug 3, 2005 | 10:25 AM
Bear River's Avatar
Bear River
Former ******
And they have standard thread dirrection. Turning counterclockwise will remove. Use O2 sensor anti seize on your new sensor, otherwise it will be as difficult to replace as the original.
Old Aug 3, 2005 | 06:53 PM
aerostar90's Avatar
aerostar90
sensor
What is a real good penetrating oil?
Ken
Old Aug 3, 2005 | 07:06 PM
Muffinman's Avatar
Muffinman
Marvel Mystery oil works good.
Old Aug 3, 2005 | 07:07 PM
96_4wdr's Avatar
96_4wdr
I like Permatex Fast Break Super Penetrant, national brand so wide availability, spray can. soak a couple times and let set overnight.
"the right stuff"
Ken
Old Aug 4, 2005 | 12:26 AM
93nighthawk's Avatar
93nighthawk
I personally like Liquid Bi, eh, Wrench, At my old job at a Bacon plant, that is all they used to remove old bolts. Now if a bolt has been soaking for a long time in bacon grease and it takes it off, then petrolium should be no problem.
Old Aug 4, 2005 | 06:12 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Ken
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 4, 2005 | 06:21 AM
96_4wdr's Avatar
96_4wdr
also helps to rap small rag around stuck O2 sensor/stuck nut or bolt and spray/soak with penetrant overnite.
Old Aug 7, 2005 | 10:18 PM
xuzme720's Avatar
xuzme720
if that doesn't work, a mechanic friend told me to use turpentine. seemed to work when all else failed on some stubborn head bolts.
Gary
Old Aug 7, 2005 | 10:29 PM
DaveMac2Vans's Avatar
DaveMac2Vans
It helps to have the slotted deep socket. I got one at Autozone for under $10.
Old Aug 7, 2005 | 11:47 PM
96_4wdr's Avatar
96_4wdr
another trick on a cold pipe is to heat the sensor base and threaded mount with a propane torch until hot then melt candle wax into threads. works better than any commercial prep. old millwrights blacksmiths trick.
Old Sep 5, 2005 | 03:05 PM
chucknc's Avatar
chucknc
My motto "if it sticks, use WD-40; if it won't, use duct tape". But seriously, if the van runs warming it up helps. If it won't run you'll need a torch as 96_4wdr said. I've never heard of the candle wax trick, one to remember.
Old Sep 5, 2005 | 05:33 PM
96_4wdr's Avatar
96_4wdr
but if under the van, don't drip any of the hot wax on face or guarenteed goose egg on head and period of unconsciousness after trying to stick head thru floorboards.
Old Sep 5, 2005 | 05:40 PM
xuzme720's Avatar
xuzme720
OMG! had pick myself off the floor after that visual! guess it goes to show, those of us without lifts, have a slightly skewed sense of humor when it comes to working on the a*.
