how to store crankshaft
Old Aug 3, 2005 | 12:38 AM
I6power's Avatar
I6power
Hey, im taking apart my 351w and now its time for the crank to come out. How should i store it while the block is being dipped and magnafluxed? I was told that a clean rag with lots of oil but i thought id ask you guys.
Old Aug 3, 2005 | 08:02 AM
wintremute's Avatar
wintremute
Spray down an old towel or rag with wd-40, wrap it up and put it in a trash bag. Tape the bag shut so no moisture can get in. Always worked for me.
Old Aug 3, 2005 | 10:50 AM
blue93f150's Avatar
blue93f150
You might as well have the crank fluxed as well. I've always oiled them, wrapped them in a garbage bag and set them upright out of the way.
Old Aug 4, 2005 | 01:00 AM
Purely Ford's Avatar
Purely Ford
I always use wheel bearing grease on the machined surfaces. Oil the rest down with a lighter oil like wd-40 or such just to make sure nothing has a chance to rust. Bag it up and stand it upright like already stated.
Old Aug 4, 2005 | 09:46 AM
Kemicalburns's Avatar
Kemicalburns
if the block is going in to the machine shop so should the crank to be checked as well. especially to check tolerances so you get the proper bearing size and might look at getting the crank journals Trued up. otherwise what everyone else said is correct.
Pitcrw6
35
Dec 9, 2010 08:19 AM
Jrock909
Electrical Systems/Wiring
Jun 3, 2007 01:32 PM
mark a.
User Gallery & Picture Display
Jun 25, 2005 12:40 AM
Rocking M
Mar 31, 2002 12:13 AM
