That's not supposed to be there....
Old 08-02-2005, 10:39 PM
Jason8705's Avatar
Jason8705
Jason8705 is offline
This is my BUSTED rod and cylinder walls!!!!
The holes were busted into the side of my oil pan by the rod...
This is what was found in the bottom of my oil pan...
Well, in the midst of all of this i'm considering a short block The only damage that I know of so far is what you see here. If this is all that it did what are yalls opinions on my decision??? It's a 5.0 EFI.
Old 08-03-2005, 12:34 AM
FSC's Avatar
FSC
FSC is offline
Judging from the pictures, the damage that I can see to the cylinder skirts tells me that you own about 800 pounds of scrap iron.
Old 08-03-2005, 02:04 AM
thomadm's Avatar
thomadm
thomadm is offline
Nice boat anchor. As far as a replacement, Id go with a long block, most of the time its worth it to spend the few extra hundred and get a complete tested motor. Unless you are looking for mods like heads and cam. Just a thought...
Old 08-03-2005, 07:13 AM
slash31938's Avatar
slash31938
slash31938 is offline
cool pictures. hope that never happens to me. id put a blown 460 or maybe a 7.2 liter diesel in my truck if that ever happened, but thats just my opinion. what kinda truck do you have?
Old 08-03-2005, 07:40 AM
jroehl's Avatar
jroehl
jroehl is offline
So, what kind of noise was it making?
My 5.0 may have just grenaded last night on my way home. I was on the interstate, when it suddenly started making lots of noise, like broken exhaust at first, then it switched to a racheting-gear-like noise, and I had very little power after that. I was thinking it might be something in the bottom of the block...
Jason
Old 08-03-2005, 11:09 AM
Jason8705's Avatar
Jason8705
Well, chances are if you didn't think you truck was on fire from all of the smoke from the oil hitting the exaust then this didn't happen to you, as for the noise, my dad was driving it at the time and from what i hear it a pretty destinctive noise, like someone banging on pots and pans. All I can tell you is this most likely did not happen to you...
Well keep comments coming....
Old 08-03-2005, 11:32 AM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
Was that a low RPM failure? It doesn't look like it grenated at low RPM. Always interesting to inspect damaged engines, glad you posted the pictures.
You could get a new shortblock 302 from ford for about $1200. Or you could go long block, or you could go 351, options are endless...
Old 08-03-2005, 12:08 PM
gov2mod's Avatar
gov2mod
gov2mod is offline
I've seen a lot of death and destruction in all kinds of engines. I had to look at a Chevy one time to see why it wouldn't start. It had thrown a rod out the side of the block and knocked the starter right off the engine. I've seen rods sticking out of oil pans, valves stuck thru pistons, you name it. I've got a piston somewhere that has the valve flipped over upside down and stuck stem first thru the top of the piston. It punched thru so fast there was a piece of piston that looked like a tootsie roll laying in the bottom of the oil pan. I once blew up a 727 automatic in a Dodge van that blew a hole out of the side of the case like a grenade went off inside of it. When things are spinning around at several thousand RPM's and fly apart it can cause all kinds of damage.
Old 08-03-2005, 01:27 PM
Jason8705's Avatar
Jason8705
Well, it happened in a 55mph zone, what i'm wanting to do is what most people want to do....torque and horsepower...but i'm not sure what the best option would be, i'm not sure how much i'm gonna spend eathier. If you guys would just throw some suggstions on what I should do (short block, long block, etc...) any help at all would be appreciated. I'll post more pics as I get them.
****The engine is still in the truck at the time...I can't get the starter off...one of the bolts that hold it to the tranny is rounded off compleately. I can't get ANYTHING to grip it. I've tried everything imaginable, nothing works...if you guys have any suggestions on this I would really appreciate that also.****
Old 08-03-2005, 01:49 PM
gov2mod's Avatar
gov2mod
gov2mod is offline
What year/model truck is it? The starter bolt should use either a 1/2" or 13mm socket. Find a six point socket that is a little too tight and hammer it on the bolt. The bolt shouldn't be that tight. After you get it out you can use a punch to drive it back out of the socket.
Old 08-03-2005, 03:53 PM
slash31938's Avatar
slash31938
what kind of a price range are you looking at? im getting kinda confused at the term short block or long block. i would think a nice I6 would be just about right if you had a 5.0, theyre fairly cheap, easy to get parts for, and have torque ranges similar to a diesel. a 335 series would be pretty nice, either a 351 or 400, those are nice and tuff, esp if you do some work to them. im not too up on fuel injection engines, so maybe im talking about stuff thats too old for what you want.
Old 08-04-2005, 02:58 PM
Jason8705's Avatar
Jason8705
Well I definately know i don't wnat a 6 cyl, i'm not saying anything bad about them, it's just that I have a custom exhaust and the 6 woulden't give it the sound i'm lookin for. I would rather stay with an 8 cyl... 302 or 351W???I don't know which...i've decided to go with a short block eathier way so if i do go eith that 351W what all will have to be done for the conversion??? Will i be able to use any of the undamaged parts on my 302??? If not that's no big deal...i'm wanting to spend 1000-2500 on the block and there's not a limit on all the other parts that i will have to buy. I'm 18 and i'm doing all of this BY MYSELF , i'm proud of myself!!!!Anyway, if you could give me a little help on choosing the best parts for a decent amount of torque and hp, this truck will be used mostly for street and hwy driving, very minimal towing or hauling, and of course there will be that occasional...wink, wink...lead foot!!!
Jason
Old 08-04-2005, 03:21 PM
gov2mod's Avatar
gov2mod
gov2mod is offline
Jason, what year and model truck do you have? If you go with a 351W you will need a donor engine from the salvage yard to supply you with the intake manifold, oil pan, etc to fit it. Of course it looks like you will need a bit of items for a 302 as well since it looks like your oil pan etc. is shot also for your 5.0.
Old 08-04-2005, 03:26 PM
Jason8705's Avatar
Jason8705
My truck is a '94 F-150XLT Ext.Cab with a 5-spd AOD tranny did have a 5.0 EFI.
The starter bold what a perfect circle nothing would fit it...i finally took a chance and drilled a hole through it and used a screwdriver to get it off....
Old 08-04-2005, 03:31 PM
gov2mod's Avatar
gov2mod
gov2mod is offline
Jason, the AOD is an automatic transmission that Ford stopped using around 1990. You have a 5 speed manual transmission, correct?
Quick Reply: That's not supposed to be there....
