keyless entry
Old Aug 2, 2005 | 02:35 PM
No2Oil's Avatar
No2Oil
keyless entry
Guys, Did all 7.3 F-250 XLT's come with keyless entry? I was told my truck wasn't equipped with it when I bought my truck. I just wanna make sure the dealer didn't forget to give me the fob.
Old Aug 2, 2005 | 03:28 PM
Medic 66's Avatar
Medic 66
What is your year? Mine is a 99.0 (not 99.5) and I do NOT have it.....unfortunately.
Old Aug 2, 2005 | 03:35 PM
1997F-350's Avatar
1997F-350
look behind your dash for the brain. on obs trucks its just to the right of the steering wheel. not too sure for your application. that is gonna be the way to tell for sure. if you find it it will have all kinds of fcc id #'s on it.
a fob brand new on ebay is 16.99 buy it now.
Old Aug 2, 2005 | 04:34 PM
No2Oil's Avatar
No2Oil
It's an 01, I can't believe I forgot that.
Old Aug 2, 2005 | 08:35 PM
charon61285's Avatar
charon61285
I have a very early 99, built 4/98 , and it has one. It is an XLT built for and sold in Canada. I added an outside keypad that you just program an stick on.
Old Aug 2, 2005 | 09:42 PM
touchofgrey's Avatar
touchofgrey
Go out to your truck. Put the key in the ignition, and turn it to "on" and then "off" eight times withing 10 seconds. Don't start the engine.....just to on then off. At the end of this exercise, the door locks should cycle if you have keyless entry. This is how you program a fob into the system. Eight times then after the locks cycle.....press one of the buttons on the new fob. Locks will cycle again indicating that the new fob is accepted.
You can get new fobs on Ebay for around $20 or sometimes less. Hope this helps.
Old Aug 2, 2005 | 10:05 PM
Medic 66's Avatar
Medic 66
Is that exercise for all years.....tried it on an early 99 and didn't work. That is turn to forward not to accessory location correct?
Old Aug 2, 2005 | 10:20 PM
touchofgrey
Thats correct. I only know about the 00 and up. The proceedure is layed out in the user's manual.
Old Aug 3, 2005 | 10:05 AM
No2Oil's Avatar
No2Oil
Must not have it. I tried the excersise a couple times and they didn't cycle. Now how do I go about getting keyless entry? I don't want an aftermarket alarm. Thanks
Old Aug 3, 2005 | 10:17 AM
touchofgrey
The most economical way would be to find a "donor" truck. I don't know how extensive the wiring harness is different from what's under the dash now. Maybe none at all. The main item would be the GEM change out. I guess you'd have to do alot of schematic studying and eyeballing of the two to be sure. Sometimes operations like this are real easy......other times it would be better to get a different truck when you look at the labor involved.
In this case.....I'd think it to be fairly easy.....because it is an option. Your dealer may have a kit just for the purpose of adding it. I think I'd start there, and then look for a donor if you don't like the price. Hope this helps.
Old Aug 3, 2005 | 10:22 AM
No2Oil's Avatar
No2Oil
Thanks Touch! You've been very helpful!
