1995 to 1996 differences?
Old Aug 1, 2005 | 10:33 PM
CT's Avatar
CT
I am thinking of replacing the engine and transmission in my 1995 F-150 4x4 with one from a wrecked 1996. Are there any wiring or computer differences between the 1995 and 1996?
Old Aug 1, 2005 | 11:52 PM
SVTCobra306's Avatar
SVTCobra306
'95 is OBD 1, 96 is OBD II, so you have more sensors and around twice as many pins/wires coming out of the computer on a 96 compared to a 95. The physical parts of the engine should interchange though.
Old Aug 2, 2005 | 07:47 AM
CT's Avatar
CT
Thanks for the insight, I didn't know they made that switch. So would enough of the wiring from a 96 wreck unplug and switch over to the 95 to make it work easily, or is it more complicated than that?
Thanks
Old Aug 2, 2005 | 01:10 PM
andym's Avatar
andym
It's way more work and complicated that you could imagine. If you didn't know there was a difference, I'm guessing that you don't understand all the differences between the engines.
If you try this, my guess is that you're going to end up with a huge mess.
Old Aug 2, 2005 | 04:17 PM
SVTCobra306
You'd have to transfer almost every single wire and harness and plug and sensor.....
Ask me, it'd be easier to just go Carb....
Old Aug 2, 2005 | 04:43 PM
CT's Avatar
CT
Thanks for the heads up, guys. I guess I was just assuming the change was between 1996 and 1997. No wonder it seems 1995 parts trucks are more scarce!
Old Aug 2, 2005 | 09:24 PM
gpfarrell's Avatar
gpfarrell
Actually, I don't think what you want to do would be that hard.
Putting a '95 engine into a '96 truck would likely be harder, because OBD-II checks lots more things than OBD-I, and you'd have to get them all right to make a '96 truck happy.
Just put the two engines next to each other and start putting the peices from the '95 on the '96, and put the peices from the '96 in a box.
It won't be as easy as doing and OBD-I to OBD-I, but I can't imagine it's a real big deal.
Old Aug 2, 2005 | 09:49 PM
EgoMan's Avatar
EgoMan
There arent that many things from what ive read but i know that there isnt a MAP sensor on the 96 because it has a MAF sensor...thats the biggest difference that I have found. Im attempting this on my 92...Its mostly just the ECU and harness aswell as the MAF sensor. If you look at the conversion kits thats all they have to them.
Old Aug 3, 2005 | 09:19 AM
Roushians's Avatar
Roushians
96 has 1 extra pre-cat o2 sensor, as well as an added after-cat o2 sensor. 2 sensors in each exhaust manifold, and 1 sensor in between the 2 cats.
Old Aug 3, 2005 | 09:41 AM
EPNCSU2006's Avatar
EPNCSU2006
The MAF conversion kits use pre-OBDII computers from Mustangs. OBD-II is an entirely different beast.
