All but given up!!
Old Aug 1, 2005 | 07:49 PM
timster's Avatar
timster
Unhappy All but given up!!
I have a 86 Ford F-150 4x4 with a 5.0L engine, and I just recently have been killing on the freeway and at stoplights. I was told it was the in line fuel pump so I replaced it. Then I replaced the rotor thinking it was bad, but I cannot figure out the problem. Anyone have any ideas? I'm thinking electrical but dont know where to start! Help!!!
Old Aug 1, 2005 | 08:39 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 1, 2005 | 09:02 PM
85F_150driver's Avatar
85F_150driver
have you checked the engine codes? have you checked the iac valve? Iac = idle Air control valve
Old Aug 1, 2005 | 09:04 PM
timster's Avatar
timster
have not checked the codes yet will do that in the a.m. just thought it might be a simple electrical problem like a tfi or temp sensor?
Old Aug 1, 2005 | 09:07 PM
timster's Avatar
timster
its almost like it just shuts off!! it doesnt run out of gas it just quits. then 5 minutes later it starts up and i drive away. its killing me! lately its taking long for it to start after it kills..
Old Aug 1, 2005 | 09:11 PM
fellro86's Avatar
fellro86
It very well could be the tfi, I had a duraspark that used to do that to me, run for a while, then shut down, let it cool, fire up and off we go... made for a long drive, kept doing this on a normally 8 hour drive. I think it ended up being about 10...
Old Aug 1, 2005 | 09:27 PM
timster's Avatar
timster
i will replace that tomorrow the more i read other problems the more i think that is it thanks for your help i will post after i try tomorrow and let you know thanks again!
Old Aug 1, 2005 | 10:06 PM
SmokyOlFord's Avatar
SmokyOlFord
If it's heat-related, clean any dirt and gunk off the suspected parts. It acts like insulation. Also check for anything that might improve airflow there. Electronics stores sell a freeze spray that will quickly cool parts down. If that suddenly gets you going, you have your culprit. Just sorta guessing here, and applying what I know about electronics repair in general.
-Ed
Old Aug 2, 2005 | 05:32 AM
RR4E's Avatar
RR4E
On that note, smokey, clean your alternator contact points(all plugs) as well as any and all ignition contacts. Going thru your fuse box won't hurt either. Older trucks may have corrosion on any and all of those, and that alone can be a trouble-spot.
Post back, and let us know.
Old Aug 3, 2005 | 10:40 PM
F3Beam's Avatar
F3Beam
Maybe make sure the battery isn't flopping around loose and shorting the circuit by touching against the body when you brake. Hey, I've seen it happen before.
Old Aug 4, 2005 | 01:34 AM
coalminer78's Avatar
coalminer78
I had a Dodge car (my first car) that did that and it was the ignition module. Hope that helps.
Old Aug 4, 2005 | 02:30 AM
turboguy's Avatar
turboguy
I had the ignition module go bad on my truck... did that for a little while.. Starting running fine.. dieing... firing back up..... and then eventually wouldnt move at all... it would idle but not go... any gas and bam shut down.
Old Aug 4, 2005 | 01:09 PM
mudgepondexpress's Avatar
mudgepondexpress
I agree with the rest, it is the TFI or Duraspark box if you are running it. That is the way they fail, heat up, quit, cool down, work, heat up, quit....
Bite the bullet and pony up to the parts counter.
Kenny
Old Aug 4, 2005 | 03:12 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Most autoparts stores can check a ignition module for you.
The most common failure is due to it heating up. When it cools down it's fine.
Make sure if you get it tested that they run it through the test at least 10 times, to heat it up. If it fails any of the tests, replace.
Hope this helps.
Old Aug 7, 2005 | 06:30 PM
timster's Avatar
timster
replaced the tfi didnt help, i maybe wrong about the heat theory it does it when its cold too. truck turns over but its like there is no gas. like i said i replaced the in line pump and i can hear it running but i am wondering if it could be the tank pump? any ideas? and thanks for the help its been great!
