Sponsored by: Kumho
Drums to Discs
Old Aug 1, 2005 | 06:41 PM
mikeyswood's Avatar
mikeyswood
Drums to Discs
Hi Guys,
What all is involved in converting the drums on a 8.8 to discs?
More importantly, is it worth it?
Thanks,
Mike
94 F-150 XLT
302 (soon to be a 351W) 5 speed 4x2
Old Aug 1, 2005 | 09:37 PM
haroldservice's Avatar
haroldservice
check out www . tsmmfg . com. they have completes and partials, give you the list of parts , and seem to have a good price. i was going to do my '76 E250 this year, but thanks to the braindead guy who pulled out in front of me my rear discs are on a mew '05 E350 6.0. darn.
Old Aug 1, 2005 | 09:58 PM
mikeyswood's Avatar
mikeyswood
Sounds like a serious bummer.
Thanks,
Mike
Old Aug 1, 2005 | 10:05 PM
haroldservice
well, yes and no, the '76 was sweet, but i am getting used to the '05.
Old Aug 1, 2005 | 11:24 PM
ivanribic's Avatar
ivanribic
Don't know about the 8.8 but I just finished up a rear disc conversion on my truck with a D70 rear and it'll lock up 44's like it's a joke. Well worth the time and money!
Old Aug 2, 2005 | 01:19 AM
haroldservice
Talking
i was thinking about an adjustable proportioning valve for the '76, to setup for load or tow or.., seemed like a good time to do it. (edit of previous post, exchanging smiley for 6.0 grin)
Old Sep 4, 2005 | 04:15 AM
Steve_Uzi's Avatar
Steve_Uzi
Now when you guys did the conversion - did you swap out the master cylinder to reflect the volume change in fluid needed for the rear discs?
Old Sep 4, 2005 | 12:17 PM
haroldservice
i was actually looking at an electric powered booster/master cylinder for my setup, i believe it came in disc/drum and disc/disc sizes, but i did not realize the need for more fluid, thanks for pointing that out.
Old Sep 4, 2005 | 12:43 PM
Steve_Uzi's Avatar
Steve_Uzi
Well most disc brake calipers have 2.5" or so diameter pistons and as the pads wear down the piston moves farther out of the caliper, that space is filled by the brake fluid - hence Disc Calipers autoadjusting. If you didn't have a big enough resevior in the master cylinder you might wind up pumping air into the system if you don't keep tabs on your Brake fluid level.
Most rear drum applications have a small wheel cylinder which is about 1" in diameter - that is about 2/3 less volume to fill it..
Old Sep 5, 2005 | 12:27 AM
aurgathor's Avatar
aurgathor
Normally, most of the breaking is done by the front brakes, so IMHO in most cases it's not worth the hassle, especially if you have ABS.
Old Sep 5, 2005 | 02:07 AM
ivanribic's Avatar
ivanribic
Steve, I have gone to a newer hydroboost setup from a Superduty with a new MC also but the company I bought my disk brake kit from does a LOT of them and he said that with full size trucks, both Ford and Chevy, he's never had to change the master cylinder OR the proportioning valve. He did mention that some smaller rigs like Yotas and Jeeps needed an adjustable proportioning valve but he said the master cylinders will work just fine. So far so good on my system. I assume the Superduty's use rear discs.
Old Sep 5, 2005 | 02:08 AM
Steve_Uzi's Avatar
Steve_Uzi
True, but that is because rear-drums aren't the best design and don't self adjust as well as they should... If you had an adjustable proportioning valve you could work it such that all 4 brakes are working in unison...
Old Sep 5, 2005 | 02:18 AM
ivanribic's Avatar
ivanribic
I don't have a clue man. I bolted it all together, bled them and I can lock up all 4 at the same time. When I was down at Blackbird's shop there was a Chevy down there they'd just put the brakes on. They tested it out in the street and it looked like there was a vacuum under the truck it sucked down so fast. All they did was bolt on the new brackets and add the disc brake calipers.
Old Sep 5, 2005 | 02:20 AM
Steve_Uzi's Avatar
Steve_Uzi
Ivanribic,
Sounds good... I guess I was thinking too much into it... something I often do being an engineer...
Old Oct 11, 2005 | 01:45 PM
goliver's Avatar
goliver
A big plus in my mind is the way better pedal feel. Nearly half the pedal distance and feels much harder.
