1978 - 1996 Big Bronco
Backup light problem
Old Aug 1, 2005 | 06:12 PM
repo_man62's Avatar
repo_man62
'94 fullsize/5.0/5 spd. Changed the switch(which I found out wasn't bad) with the switch out of the truck...I can push a ball bearing on the switch in and the lites work. When I put it(switch) back in...they don't work. What activates the switch? A gear?Rod? Vac? Elect? Can I access it thru the Hole for the shifter if I take the boot off and take the top shifter plate off? HELP!
