roller rockers
Old Aug 1, 2005 | 02:35 AM
bootie's Avatar
bootie
roller rockers
does fitting roller rockers make any difference to the length of pushrods required std
Old Aug 3, 2005 | 11:47 AM
RTM's Avatar
RTM
It all depends on what brand you are using and maybe a few other things but it's always best to measure for the correct length. if you have late model heads with the style that just get torqued down and you use all ford parts you may not need to change the push rods because the ford parts should be made with in spec so they can simple be bolted on. This has been my experience but there is always something different that can get you so measure to be safe.
Old Aug 3, 2005 | 06:39 PM
SVTCobra306's Avatar
SVTCobra306
Plus if the pushrods end up too long you can us a crane or ford shim kit to shim up to .090, anything over that and you need shorter pushrods.
