'66 front disc convertion
Old Aug 1, 2005 | 02:16 AM
fordracing013's Avatar
fordracing013
I have been told that in older to convert the front to discs i can get the spindles, discs, proportion valve, and mountin hardware off of a '73 ford truck. In doing this i would have to use the master cylinder from the donor truck as well. is there any other master cylinders that i could use, like a mustang or bronco that would work just as well?
Old Aug 1, 2005 | 05:31 AM
ddavidv's Avatar
ddavidv
Do a search for "Mustang master cylinder", there's several posts about which ones to use. The only downside to using the truck m/cyl is you have to cut the pushrod down that attaches to the pedal. Not that hard, really. Have you found my how-to page on doing the swap? Click here.
Old Aug 1, 2005 | 06:38 AM
jowilker's Avatar
jowilker
fr013, Welcome to FTE The best truck show on the net.
There are two trains of thought on the swap. Because there are some little differences, I recommend swapping the complete I-beams, steering gear, master cylinder & booster, porp. valve, everything from a single source donor. You are keeping with a engineered system, and not some back yard system. I would install a new reman ms and pads with the upgrade, although if it was working on the donor it should still work.
I have heard of issues with kingpin out upgrades that don't happen with the complete swap. The main reason that I recommend the total package is that most of us are amitures in this area, we are less likely to run in to snags.
I bought a 76 F100 and swapped everythng under my 66 F100.
wishing you the best
John
Old Aug 1, 2005 | 04:27 PM
Customcab's Avatar
Customcab
Just to add to everyone else reponse WELCOME ABOARD; you have tap into the finest web site involving the entire FORD Motor fleet;and to just add to John's and the others comment you can use 78 and below f100 front end clips. I also here that a 68 mustang M/C was a direct bolt on and easily purchase thru your favorite Auto Parts store.
Again Welcome aboard; also suggest you do a "Search this Thread" to look up past threads involving this conversion. Probably the most talk about conversion on the site.
Mitch
Old Aug 2, 2005 | 06:22 AM
jowilker's Avatar
jowilker
Mitch, Any reason to leave the 79 out?
Just wondering if I had missed something.
John
Old Aug 2, 2005 | 09:44 AM
FordBoypete's Avatar
FordBoypete
Thumbs up
I also welcome you to FTE
I agree with John, if this is your 1st go round, use the whole set up, twin I beams & all and 73 to 79 will all fit & work when used this way.
While you're at it go ahead and R&R your bushings for the I Beams & radius arms. Another point to consider is you may realize a front anti sway bar is a great improvement. There's no provision to mount it on 65-6 radius arms, but there is on 73-9 radius arms. If you'd used them (73-9) radius arms to start, addition of front anti sway bar's a virtual "bolt up deal".
Often when conversion is performed "spindles outward" [otherwords kingpins outward] there can be lock pin location & kingpin diameter issues. These can stem from axle load rating, year of manufacture, truck model [camper/trailer special] and so on. To get around all that use entire subassemblies like John points out.
As for your original question, the master cylinder you do use should come from a disc brake system. What advantage do you expect to gain by using another M-Cyl besides one for a truck?
Plus, are you aware the "hot set- up" for a brake light switch is later, pedal arm, contact type is preferred over early pressure style switches used on our SLICKS originally? With discs you'll stop qwiker, and with the old pressure wsitch your brake lights light later/ slower. IOW you are already stopping B4 the brake lights come on.
That "second" of time is worth 88 feet at 60Mph, FWIW. . . .
Well, anyway Welcome again to FTE & be lookin for you in the forum. . . .
FBp
Jmiller68
Mar 12, 2017 07:12 AM
HRDROKN
Jan 17, 2010 01:22 PM
F350moneypit
16
Aug 15, 2009 02:50 PM
imlowr2
Oct 7, 2008 11:43 AM
user 5363849
May 24, 2002 01:14 PM
