Brake warning light is haunted
Old Jul 31, 2005 | 08:58 PM
Truckmano5's Avatar
Truckmano5
I was driving to the dump today and my brake warning light came on for a few minutes. My parking brake was off (since it doesn't work anyway ) so what could this mean? My passenger-side front brake has been dragging enough to put a pull on the steering and braking
Old Jul 31, 2005 | 09:01 PM
Greg 79 f150's Avatar
Greg 79 f150
Indicating low brake fluid level because the passenger side front brake , has a wheel brake cylinder leaking maybe ??
Old Jul 31, 2005 | 09:03 PM
V10KLZZ71S's Avatar
V10KLZZ71S
I think there is a proportioning valve under the truck with a switch that will light the light if it moves too far one way,[if my memory serves me correct].Man I am digging deep into my brain on that one.
Old Jul 31, 2005 | 09:14 PM
plowpusher's Avatar
plowpusher
check the adjustment of your rear brakes probably way out of adjustmest causing a lot of wheel cyl travel sometimes enuff to cause a brake cyl to loose its seal thus looseing brake pressure then the springs will push it back together the brake waring light is not connected to the E-brake on this era truck only to the proportioning valve to sense loss of pressure in the brake system and if a failure occurs the proportioning valve is spring loaded to block the end that looses pressure
Old Jul 31, 2005 | 09:36 PM
V10KLZZ71S's Avatar
V10KLZZ71S
So I do have some brain cells left!
Old Aug 1, 2005 | 07:33 AM
76supercab2's Avatar
76supercab2
It means you have a problem with your brake system and you need to stop driving the truck until you figure out what it is and fix it.
Possiblities include:
Low brake fluid (but where did it go?) which means a leak somewhere
Bad master cylinder
Bad rear brake cylinders
Leak somewhere (bad hose or steel line)
There is no connection between the emergency brake and the brake warning light.
Old Aug 1, 2005 | 09:29 PM
Truckmano5's Avatar
Truckmano5
If a rear brake cylinder on the pass. side is bad and/or leaking, will this cause the front brake on the pass. side to drag?
Old Aug 2, 2005 | 08:10 AM
76supercab2
It shouldn't. The reason there are two chambers in the master cylinder is to separate the front and rear brakes.
Old Aug 2, 2005 | 08:19 AM
1975Ford's Avatar
1975Ford
What is the year, make, model, 2wd or 4wd?
