hey all,
i'm new to the list and my 95 ford van will not start. all i did was clean the battery cable and post connectors.i put them back on and the fuel pump is not turning on.i have no burned out fuses and the auto-shut off for fuel is not tripped.i did trip and re-set it .has anyone had this happen??what else could cause this
...Welcome sjpatpggc, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
If you get nothing when you turn the key, turn on the headlights, if the lights don't dim while you turn the key again. Check for a loose "thin" wire at the starter. click here http://www.woodalls.com/cforum/index...3.cfm#15785473 read "MJBGRI and FOURTHCLASSc" posts should be 18 posts down.
Go over every thing you did.I took the face plate off my dashboard to replace the radio.When i put it back i pushed a live wire to the cig lighter up into a piece of metal,and the motor didnt start.oops.
