Distributor/Timing
Old Jul 31, 2005 | 12:21 PM
inkpusher2004's Avatar
inkpusher2004
Question Distributor/Timing
I have a 1972 F100 with only 45,700 actual miles. The motor runs smooth, but sometimes it will begin to skip and eventually stall. I have to loosen the set bolt and slightly turn the distibutor, then the truck will restart and run fine. Does anyone have any ideas? Your help would be greatly appreciated. My email address is: inkpusher2000@yahoo.com
Old Jul 31, 2005 | 01:02 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved and member Notifed
Old Jul 31, 2005 | 04:54 PM
fordxxx's Avatar
fordxxx
I think the low voltage return path is through the body of the distributor to the engine block and back to the negative of the battery. Maybe sometimes you don't have good contact between the dist. and the block. If you cleaned off the hold-down clamp and the lip where it contacts the dist. it might help.
Old Jul 31, 2005 | 05:15 PM
inkpusher2004
I am new at this forum thing. I sent you a "thank you" earlier, but I am sending again in case you didn't get it.
Old Aug 1, 2005 | 03:26 PM
1975Ford's Avatar
1975Ford
Things to look and inspect.
  1. It seem like your points are shot. (Replace points and condenser)
  2. Remove the distributor housing and visually inspect the lower gear cotter pin is not sheared. (replace cotter pin)
  3. Verify the the counter weights on distributor is working correctly.
Option 1.
Replace items on distributor which are broken.
Option 2.
Replace distributor.
Replace O-ring on distributor housing.
Good luck
Old Aug 1, 2005 | 03:41 PM
inkpusher2004
Thanks for your help. It is much appreciated!
Old Aug 4, 2005 | 10:34 AM
fling's Avatar
fling
Does the dist. clamp have to be clean?
I painted my dist. housing and my hold down but motor runs fine.
