Wrong Head Gasket?
Old Jul 31, 2005 | 11:27 AM
furz4's Avatar
furz4
Wrong Head Gasket?
I just started the new engine in my truck and have alot of white smoke and bubbles in the cooling system. Looks like I have a head gasket problem. The engine is a 351W with a early block(was in a 85 bronco) with a 79 casting date and newer E7 heads. Truck is a 91 F250 and I used the gasket set for a 91. Is it possible I used the wrong head gaskets? I am going to check compressin and see if I can pinpoint the problem. I don't see any antifreeze in the oil so I don't suspect a crqcked block. The heads are re-man units done by a reputable shop but I supose a cracked one could slip by if the did not magnigflux them. i have rebuilt lots of engines over the years and never had a problem like this with a new engine.
