vibration in truck
Old Jul 31, 2005 | 09:16 AM
01fordranger's Avatar
01fordranger
vibration in truck
I have a 01 ford ranger it has a vibration when driving done the road at 55/60 miles per hour. The problem is that it the vibration goes away once your foot is taken off the gas pedal. bearings, tierod ends, and tires appear okay.. any thoughts other equipment to check???
Old Jul 31, 2005 | 11:37 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 31, 2005 | 11:42 AM
n0mxj's Avatar
n0mxj
Block your wheels, and check the U-joints in the driveline. Also check for road debris wrapped around driveline.
Old Jul 31, 2005 | 12:09 PM
claybuster1815's Avatar
claybuster1815
i experienced a similar problem with my '94 ranger. the u-joint caps for the rear drive shaft were loose. the center carrier bearing was bad which was causing enough drive shaft vibration to loosen the u-joint caps.
Old Jul 31, 2005 | 12:14 PM
frankenbroncoII's Avatar
frankenbroncoII
a friend of mine has a 98 ranger 4.0 auto 2wd and he had a bent driveshaft that was causing a bad vibration.. it also ripped the rear tranny seal and leak fluid.
Old Jul 31, 2005 | 08:15 PM
J McGuire's Avatar
J McGuire
The first place to look, and least expensive is to have the wheels balanced. When you have this done, the wheel/tire technitian will notice if the allignment is the problem and bring it to your attention.
