Won't start - no spark
Old Jul 31, 2005 | 08:33 PM
kellison's Avatar
kellison
I have a 94 Ranger Splash with the 2.3L. The truck died on me today just after leaving the drive way and would not start again. I pulled the codes but there was none. I can hear the fuel pump engage when I turn on the ignition. I put a new spark plug in one of the spark plugs wires and turned the engine over but there was no spark wit it touching a ground. I went and bought 2 new Ignition coils and that did not help. Then bought a new Ignition Control Module (ICM) still did not help. I took out the Inertia switch and put in a jumper cable no help. I checked the fuel relay - had a new spare, checked the ECC Pwr & IGN Fuses in the fuse compartment near the engine and they do not look blown. I noticed one that says "Diode" does not look like a regular fuse not sure what that is for. Tried switching the EEC Power Relay with the A/C Relay that did not help. I do not know what else to try or check. Any help ???
Thanks Ken >
<!-- / message -->
Old Jul 31, 2005 | 08:52 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
..Welcome Ken, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 1, 2005 | 09:44 AM
jinx102672's Avatar
jinx102672
I don't know a whole lot about these things, but I do have some questions/suggestions. Did the timing chain/belt break? Do you think maybe the coils and plugs are good but the actual plug wire is bad? I wish I knew more about these things. Good luck.
