Bronco II Ford Bronco II
tool for auto hub
Old Jul 30, 2005 | 01:18 PM
Avanti's Avatar
Avanti
tool for auto hub
I need to grease my 89 Bronco II 4 wheel drive hub bearings. According to the Chiltons I need a 2 & 3/8 in hex socket to remove the adjusting lock nut on the hubs. The socket is different than the one for the manual hubs. Advance Auto only has the manual socket. Where can I get the correct socket? If the worse case will a large pipe wrench work?? any ideas?
Old Jul 31, 2005 | 01:53 PM
Canadianice's Avatar
Canadianice
My shop manual says the same thing, I dunno if a pipe wrench is a good idea. Also If I remember you need to torque that nut down to a specific torque so I would search for a socket for it.
Old Jul 31, 2005 | 06:29 PM
mrshorty's Avatar
mrshorty
I got mine at Napa (I don't know why most places have such a hard time with that auto hub socket).
Channel locks or other pipe wrench should be good enough for getting it off; it isn't on very tight (16 in lbs). You might be able to get off simply with your hands. Canadianice is correct about putting things back together. It would be a lot easier to get it set correctly with the proper socket (and a good inch-lb torque wrench).
Old Aug 1, 2005 | 09:31 AM
80351's Avatar
80351
tool for auto hub
Just about any parts store has them. Napa had one but too much money for my empty pockets. Wound up at Salvo where they had a generous supply of all the hub sockets and cheap too.
Dave
Old Aug 5, 2005 | 11:07 PM
80351's Avatar
80351
Did you ever get your socket?
Eli1644
Feb 2, 2017 05:41 PM
Iaff113
Oct 25, 2016 12:46 PM
scottddove
Aug 12, 2015 12:48 AM
Macs1964F100
Jul 15, 2014 07:32 AM
