wobbling fuel pump
Old Nov 7, 2002 | 10:56 AM
Ford_Six's Avatar
Ford_Six
wobbling fuel pump
Old Nov 10, 2002 | 09:47 PM
fordmaniac21's Avatar
fordmaniac21
wobbling fuel pump
i put an aftermarket oil preasure guage in my truck today and after i hooked up all the lines. when i was checking it for leaks i noticed that my fuel pump filter bowl was moving up and down evry tiime the pump pumped. i checked the bolts holding it to the block and they were all tight along with everything else. it was just the pump bounceing everytime the cam for the pump went up. i know this sounds weird but i just want to make sure that the pump isnt going bad.
'75 F-100 4x4, 4" lift
35x15.5x15 super swamper TSL/SX
mini-spooled 9" rear end
390 w/ cam,headers,
and 4 barrell edelbrock
TRIED TRUE and FORD BLUE
Old Nov 10, 2002 | 10:07 PM
LxMan1's Avatar
LxMan1
wobbling fuel pump
Sounds like the pump housing may be cracked. If it is tight up against the block, and it is moving, I would replace it before it breaks and leaves you stranded or even worse, causes a fire.
Old Nov 11, 2002 | 09:30 AM
fordmaniac21
wobbling fuel pump
hmmmm that is what i was afraid of. ill have to look closer and see if it is cracked. i guess if it is cracked i will prolly upgrade to a electric fuel pump or a better mechanical one.
390 w/ cam,headers,
