?????s on tranny
Old Jul 29, 2005 | 07:44 PM
otpracer100's Avatar
otpracer100
?????s on tranny
guys,i need some experience here.I'm fairly sure it's my tranny that went bad.There are alot of metal shavings in the bottom of the pan.Before i took the pan off, if i put it in drive 1 or 2,let off the brake and touched the accelerator i would hear a scraping/spinning noise.Does that sound like it's the tranny? I want to make sure before i drop $3500 on a tranny.I shifted through the transfer case gears too with no results.Anyone think it could be the tranfer case?Thanks
Old Jul 29, 2005 | 08:07 PM
18vtx00's Avatar
18vtx00
Smile
doubt the transfer is bad, but you should check the fluid too to see if it is clean or metallic anyways
Old Jul 30, 2005 | 12:47 PM
EBSTEVE's Avatar
EBSTEVE
It could be the TC but that will put pieces in the trany so either way you will be tearing into the trany, I know I did it two weeks ago.
