Any solution for early model 99 (8/98) turbo surge?
I am in the process of applying the following modifications to my early model 99 (manufacture 8/98) F250 PSD:
I have been reading a fair bit about turbo surge especially for those that tow heavy loads. I originally was going to add the "wicked wheel" while I was doing the exhaust given the downpipe was going to be removed during the process anyway.
However, the turbo specifications for the early 99 and the 99.5 and beyond are different. The wicked wheel is only for 99.5 models and newer. Additionally, the Turbo Housing kits I've found so far are also only made for the 99.5 and newer models.
Three questions:
1. Does the early model 99 experience the same problems with turbo surge as the 99.5 models and newer.
2. Is there a way to predict under what circumstances turbo surge may occur?
3. Other than installing an expensive $$$ Early 99 turbo conversion kit are their any other solutions to address turbo surge on the Early 99's?
- Air intake (kwik mod - 6637)
- MBRP 4" downpipe/exhaust
- Guages (pyro, tranny temp, boost)
Three questions:
It is my understanding that when they redesigned the 99.5 they also changed the turbo, wheel, etc. The early wheel worked OK. It was when they changed the turbo/wheel, is when the problems occured. For example, if you order the stinger-plus from Banks for the 99.5, they include new wheel. If you have the early 99, no change is necessary. There no wheel is included in the package.. Simply put, the early '99 wheel is the same as the wicked wheel. Carroll ( there are many posts on this subject but probably a year or so ago)
QUOTE=bowedup2003]Early 99's have different compressor wheel in turbo and different air cleaner housing. The compressor wheel was changed midyear because some felt the turbo whistle was too loud. The late 99's with the new style compressor wheel are prone to turbo surging when under a load, and most people swap in the Wicked Wheel or the Banks Quikspool compressor wheels to fix the problem, which are identical to the early 99 compressor wheel
