Ash Tray Repair.
Old Jul 29, 2005 | 12:07 PM
Tech 1's Avatar
Tech 1
Ash Tray Repair.
Here is an old tip (that may have been mentioned before and forgotten) for you guys that have a problem with a sloppy ash tray fit in your trucks if the ball bearings are missing or worn. I know this works on 69-72 models. Remove the ashtray and the ball bearing carrier. Then clean out the grooves on each side of the ash tray. Sand them really clean. Then cut a piece of 5/16 copper tubing to fit in the groove. Sand the copper tubing squeaky clean and then take some flux and solder and solder the tubing into the grooves. Apply some white lithium grease to the slides and you have a tight ashtray.
Old Jul 29, 2005 | 12:53 PM
Freightrain's Avatar
Freightrain
Hmmm, neat idea. The only problem is I think the copper would wear thin pretty quick on mine..........only cause of the WEIGHT of change that I carry in the ash tray........LOL!!!!!!
Old Jul 30, 2005 | 07:44 AM
jowilker's Avatar
jowilker
I got a better suggestion, WELD it shut and quit smoking. The golden leaf will kill you.
John
Old Nov 5, 2012 | 09:27 PM
nick.dalpiaz's Avatar
nick.dalpiaz
Thanks, i will try. Could not find bearing slide anywhere
Old Nov 5, 2012 | 10:25 PM
lilsmokey's Avatar
lilsmokey
John
Or even beter. Pull it out. Drill a few holes in it. And mount a new interior light! Also fill the ash trey with wiring and spare bolts.
Old Nov 6, 2012 | 03:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ashtray Ball Bearings.
The usual reason for sloppy ashtray fitment on 1968/72 F100/750's: The ball bearings are either worn or have fallen out.
354872-S .. Ash Tray Ball Bearing (takes 2 per side) / Obsolete
AL BILTON FORD in Holly Hill SC has 4 = 803-496-3150.
PREAUS MOTOR CO. in Farmerville LA has 25 = 318-368-3805.
LYLE'S FORD in Eagle Grove IA has 26 = 800-397-6319.
DELONG FORD in Winnemucca NV has 35 = 775-623-5049.
DON SANDERSON FORD in Glendale AZ has 71 = 623-842-8643.
GREEN SALES CO. in Cincinnati OH has 456 = 800-543-4959.
Old Nov 6, 2012 | 08:56 AM
MIKES 68 F100's Avatar
MIKES 68 F100
OR go to junk yard and get a good used ash try , mine was missing a ball bearing
$1.00 ash tray from pick ur part problem fixed
Old Nov 6, 2012 | 06:56 PM
NumberDummy
How many junkyards have any 1968/72 F100/750's? Here in SoCal, not very prevelent elsewhere.
Old Nov 6, 2012 | 08:01 PM
MIKES 68 F100
ok search ebay then
Old Apr 26, 2024 | 03:00 PM
Coffee49's Avatar
Coffee49
4wd High
Ashtray install
I found one complete on ebay. had to whire wheel and emery the thing and put fresh grease in bearings. I don't smoke but was sick of looking at that hole in the front.
Old Apr 28, 2024 | 02:51 PM
RTT's Avatar
RTT
Red face
Will/can u show me the bearings carrier ???
I never knew there are bearings involved
Old Apr 28, 2024 | 02:59 PM
Coffee49's Avatar
Coffee49
4wd High
Ash tray bearings
2 bearings on each side that ride in symmetrical grooves, a wrap around cage holds the bearings in place
JimG1098
Apr 29, 2015 11:18 AM
jrockdiddy
15
Mar 17, 2015 11:05 PM
GamerGirlAlice
WTB - Parts & other
Mar 9, 2015 12:19 PM
drptop70ss
15
Mar 7, 2015 07:57 PM
Jaime74656
Nov 10, 2014 10:02 AM
