looking for #2
Old Nov 14, 2002 | 11:25 AM
joetee10's Avatar
joetee10
looking for #2
Old Nov 14, 2002 | 08:56 PM
gotmyfirst1's Avatar
gotmyfirst1
looking for #2
i want to get a '77 f-150 shortbed but put my 460 eng in it, along with my suspension off of my f-250...i don't plan on doing any major hauling just occasional odd jobs or what ever....the qustions are:
1. is it an easy transfer or just new motor mounts?
2. will the f-150 frame hold up okay?
3. can an engine be switched from an automatic tranny to a manual
easily? or does it wear on the engine more/less?
4. what is normal to pay for a late 70's body in decent to good
condition with no motor or tranny? I live in northern IN if that
info would help anyone get me more accurate prices.
5. will i get better mpg with the f-150 rearend than with my f-250
rear?
Thanks in advance for any advice/knowledge any one can pass this way!
Old Nov 14, 2002 | 09:13 PM
Mil1ion's Avatar
Mil1ion
looking for #2
Regarding the Swap.
If you use the a search function for this forum ,you will find at least 50+ threads related to the 429/460 swap.
Just type in "460 swap"
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 14, 2002 | 09:36 PM
LxMan1's Avatar
LxMan1
looking for #2
>manual
>good
>if that
>f-250
> rear?
>this way!
The F-150 frame is the same as an F-250. Only yhe suspension is beefed up. The F-250 rearend is probably geared lower and will decrease mpg. But is you mix the 2, you will have 8 lugs on one end and 5 on the other. You will need 460 frame mounts if it doens't have a 429/460 in it now. It's not real difficult to change from an auto to manual tranny, if you have all of the pedals and linkage required. An auto is a little easier on the crank and bearings, but if it is driven 1/2 way normal (not alot of revving it up and dumping the clutch) it really won't make a noticable difference.
You may also check the 385 Series forum and the tranny forum for more detailed answers.
Jimmy
