water pump?
Old Jul 28, 2005 | 06:55 PM
jerrya's Avatar
jerrya
water pump?
Does anyone know how to get the fan off the water pump?
2000 ford explorer sport 4.0L OHV
Thanks
Old Jul 28, 2005 | 11:46 PM
Jharger's Avatar
Jharger
REMOVAL
1. Drain the coolant. Detach the radiator lower hose and the heater return hose from the water pump.
2. Remove fan and clutch assembly using Fan Clutch Pulley Holder T84T-6312-C and Fan Clutch Nut Wrench T84T-6312-D or equivalents. Remember primative pete - use the right tool for the job!
3. Loosen the alternator mounting bolts and remove the belt. Vehicles with A/C, remove alternator and bracket.
4. Remove the water pump pulley.
5. Remove the water pump assembly attaching bolts and remove water pump assembly.
Old Jul 29, 2005 | 05:46 AM
marragtop's Avatar
marragtop
Make sure you know whether the fan is held on with a right hand or left hand thread. I've seen some vehicles that use a left hand thread. Not sure about the 2002 Exp. I'm sure someone on the board will know.
Old Jul 31, 2005 | 11:51 AM
jerrya's Avatar
jerrya
water pump
thanks i got it off and changed out.
Old Jun 24, 2010 | 08:26 AM
royt911's Avatar
royt911
clutch fan tool don't work
This tool doesn't work on a 96 Ranger 3.0. Looking at this drawing and looking at my pulley, there is nothing to grab onto. I know some may disagree with me but you have to look at a Ranger 3.0 too see.
Old Jun 24, 2010 | 08:58 PM
aquanaut20's Avatar
aquanaut20
The wide mouth spanner (rear one) fits astride the 4 pulley bolts. 10 min and mfg my own...the clutch spins on CC...
arcticatdan
Jan 31, 2014 10:04 AM
bruno2
Nov 7, 2013 04:43 PM
B 3000
1983 - 2012 Ranger & B-Series
Mar 12, 2009 09:18 PM
frog
Apr 1, 2006 03:44 PM
Mikeman
Aerostar
Aug 22, 2002 02:00 PM
