Door Codes breakdown
Old Jul 28, 2005 | 04:38 PM
Ford5.4L's Avatar
Ford5.4L
Talking Door Codes breakdown
Hey everyone,
I have a question about door codes in a 89 F-150 My transmission code is K, which I believe is the C6, the axle code is 12, I don't know what that means. Any help will be appreciated. The truck has a 300 6 cylinder, auto, and 2WD with helper springs. I have tried searching the forum, as I have seen the codes somewhere, but I cannot find them. I don't think that I am searching properly. So, if you don't know the codes, but have suggestions on the search, I'll take that too! Thanks again.
Old Jul 28, 2005 | 10:33 PM
95X15's Avatar
95X15
Transmission code K is A C6 as you identified; axle code 12 is a 2.73 ratio standard (Ford 8.8" ring gear, I believe) 3800# rated unit.
Old Jul 29, 2005 | 06:12 AM
Ford5.4L's Avatar
Ford5.4L
Thanks very much!
