Human Horse Power
Old Jul 29, 2005 | 07:34 AM
stu37d's Avatar
stu37d
Government Teat-sucker
Originally Posted by Torque1st
If you run that mile straight up...
Isn't hp determined from lifting something with pulleys? I mean, if I could out pull a 1hp motor (say, a go-cart) wouldn't I be generating that much HP?
Old Jul 29, 2005 | 08:16 AM
D-ranged2.5's Avatar
D-ranged2.5
"it's defined as the work required to raise 550 pounds a distance of one foot in one second"
That's the definition of hp on this site: http://outside.away.com/outside/envi...01wildfile.adp
If you take time to read the article (third question down I think) it mentions why horsepower can't be measured by simply distance, body weight, and time... it also says that the world's strongest man could generate 5.84 hp.
Old Jul 29, 2005 | 10:24 AM
mc01svt's Avatar
mc01svt
Originally Posted by FghtinIrshNvrDie
no, no, no... we did an experiment in 7th grade. we ran up the stairs, it was pre-measured how far to run, timed, and done according to body weight. I got somewhere around 7 horsepower as a 7th grader. I'm gonna say average male is 12-14 horsepower. Remember, we're not geared. Also, my science teacher may have been full of balogna.
Ryan
yes, your science teacher was full of balogna. humans only make a fraction of a horsepower.
1 hp = the ability to vertically displace 550lbs, 1ft in 1sec
Old Jul 29, 2005 | 11:06 AM
jim henderson's Avatar
jim henderson
HP is the RATE of doing work, Torque is the instantaneous force over a distance, usually one foot.
A horse does not raise 33,000#s all at once. It is the amount of total weight moved over a set time frame. Probably detailed in the Wikipedia article.
Likewise a tiny riceburner car has lets say 100 foot pounds of force. That means in non scientific terms that the engine can sustain 100 pounds of weight at a distance of 1 foot without stalling. Doesn't mean it takes a minute to do it, the force is constant. This is also the force a typical man could easily exert, we do it all the time when we torque some lug nuts. 100 foot pounds is pretty puny.
However that same car can move its weight say 2,000# up a hill much faster than than a man exerting 100 foot pounds could.
Probably lousy examples, but HP and Torque are not the same but they are related over time.
Just my unscientific opinion,
Jim Henderson
Old Jul 29, 2005 | 01:35 PM
ARMORER's Avatar
ARMORER
But also, when you are torquing a bolt to 100 lb/ft you have a tremendous mechanical advantage over the fastener due to the length of the wrench.
Old Jul 29, 2005 | 04:43 PM
ddrumman2004's Avatar
ddrumman2004
So if a 550 pound man stepped up on a one foot high stool in one second.....he's putting out 1 hp?
Old Jul 29, 2005 | 05:26 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
that's the impression I get. Climbing would be the best way to really get your horsepower reading. I dunno though...
Ryan
cmpd1781
Nov 10, 2008 08:03 PM
2005deathrattle
New Member Introductions
Mar 27, 2008 09:53 PM
Bruker
Oct 22, 2007 09:26 PM
sixtyfive_ford
Jan 20, 2007 07:08 AM
