Increasing Air Flow - Bronco
Old Jul 28, 2005 | 01:07 PM
draythomp's Avatar
draythomp
I have a black (wasn't I dumb) 1987 Big Bronco and the air conditioning doesn't keep up with the desert heat. It blows cold, I had it checked and a bunch of stuff repaired, but it just won't keep up with 114F outside. I see two problems, there just isn't enough airflow and the fiberglass top transmits heat inside at a huge rate.
I plan on painting it in the future, but the cost is out of my range right now, black to white repainting is expensive. I think insulating the fiberglass top will help a lot, but I haven't figured out how to make it look good yet.
How about airflow? This era Bronco is notorious for not blowing hard enough so maybe there's a fix that can be done there. I've checked my airflow with others and it seems the same, but it just doesn't push the air into the back seat worth a darn.
Yes, I opened up the vents and cleaned out the leaves and such that had accumulated around the evaporator. I hooked up a leaf blower and blew out the vents directly to be sure. The max A/C door works fine (had to fix that too) and it recirculates fine. There just isn't enough cabin air.
Is there a high power blower motor that can be installed?
Old Jul 31, 2005 | 03:05 PM
Ultramagdan's Avatar
Ultramagdan
I think you nailed the issue when you mentioned the 114 heat and a fiberglass roof. It's going to be difficult to see much of an improvment in such adverse conditions. The insulation on the roof would make a noticable difference. You could try some cheap home insulation with reflective foil and see if helps. It may look bad but you can do it cheaply and try it out.
EAGLESBEAK
Bronco II
Nov 7, 2023 05:05 PM
172pilot
Oct 21, 2013 09:17 PM
Jeepincj7
Dec 16, 2012 10:25 AM
denali05
Dec 27, 2009 02:02 PM
