Have any of you guys used this stuff....I think it is higher or purely Ethanol.....they are selling it for $1.89/gal in denver....just wondering if it was good or bad, and special tuning requirements, etc.?
It is an alcohol fuel that is available for flex fuel vehicles, and under the right conditions can be used on older vehicles. The conditions have to be done in order to run it with no damage to your system. There a many threads in the alternative fuels forum, you will find plenty of information there.
someone help me out one this
What is it and where can it be found?
-Brandon-
Brandon, Go out to the main Forum page, and scroll down past the engines to Misc. and look for Alternative Fuels, Hybrids and Increasing Mileage. Should be about the 3ed one down. Do a little research there and you will be enlightened.
Sounds like several parts need to be modified or replaced (Modify the carb for the fuel, new neoprene lines and seals...and possibly a different fuel pump)....I have found the fuel at only one place in Denver at 1.89/gal.....regular 85 octane gas here is about 2.19/gal.
Here in town there is only one station that is selling it for $1.99 a gal. Yes you will need some mod's to use it. Most of it is made from corn, although some other veggies are used too. The farmers are loving this in the midwest?
