Replacing a 99 Expy Fuel Pump
Old Jul 28, 2005 | 12:41 AM
Blackburne25's Avatar
Blackburne25
Earlier this evening I was on a business call and whil idling in the parking lot, my 99 Expy just turned off. I tried to start it but to no avail. To make matters interesting I was in a small town 50 miles north of my home. No mobile repair available, I tried to jump it, but the battery power didn't seem to be the issue. It just felt that there was no gas getting through (1/2 tank).
So I called a towing company, as he rattled the vehicle on the truck bed, I was able to start it. Not wanting to risk it going out again, I forked $200 and had it towed home. Due to the tight budget I'm on, I'm considering with the help of a friend who is somewhat of a mechanic to help me change the fuel pump. Is this hard and difficult to do? I've worked on other repairs on the vehicle.
Sorry for the novel and thank you for any comments in advance.
Blacks
Old Jul 28, 2005 | 07:06 AM
01silvergt's Avatar
01silvergt
What makes you think its the fuel pump? When you turn the ket to the "on" position (do not start it) do you hear the fuel pump or not? It could be other things besides the fuel pump.
Old Jul 28, 2005 | 09:38 AM
Blackburne25
Silver,
Thanks for the reply, that was just my first assumption, I am going to change the fuel filter first, I realized after my post that if it was the fuel pump then my expy would not have started this morning. I bought a fuel filter this morning and will change it, the fella at Advance Auto also mention an ignition module.
Do you know if a fuel pump just goes out completely, or does it just act sluggish over a period of time then goes out?
Thanks,
Blacks
Old Jul 28, 2005 | 02:53 PM
gibsonj's Avatar
gibsonj
If the pump has a short, it can just go out on you without warning. I've had them quit, go around and bang my fist against the underside of the tank, and have it go to work again for awhile.
BTW, when you tried to restart your Expy, did you happen to try feathering the accelerator a bit in addition to just turning the key? Sometimes when the IAC gets a little wacky on these vehicles, they will crank and crank, but fire up when you give it a little gas...
Just a thought.
Old Jul 28, 2005 | 03:57 PM
PaulC's Avatar
PaulC
And a pretty good one at that.
Old Jul 28, 2005 | 05:20 PM
Blackburne25
I definitely tried to get the pedal going but to no avail, as I had to help steer the vehicle on the tow truck, I turned the ignition and sure enough it worked, it seemed a little jostle allowed the fuel to flow through.
I have never changed the fuel filter in the 4 years that I have had the vehicle, I will attempt to change it for the first time and I've been reading another thread, I will start changing it out every other oil change. I went home for lunch and my Expy started right up with no problem at all. I won't drive it until I get the new filter on.
If it does go out, I'll just club the underside of the tank as suggested
