Sponsored by: Real Truck
Why does my trans suck?
Old Jul 27, 2005 | 09:14 PM
jokerforever's Avatar
jokerforever
Why does my trans stink?
I have a 2001 F350 4x4 SRW with a V10 and a 4R100 Auto. I bought my truck with 60,000 +/- miles on it. At 75,000 the trany ate it self alive. The only thing that could be saved was the case and some hardware. I had it rebuilt by a reputable shop, only because I had just moved three states south and didn’t have time to do it myself, and they told me that they use “all the best parts available.” After the rebuild the trany acted OK, and as good as it was before, but I wasn’t very happy with it. I installed a Transgo shift kit and it helped but still it didn’t want to act right. The thing always seems to be confused; down shifting at the wrong time or into the wrong gear, sometimes holding a gear too long, sometimes up shifting too soon, slow shifts that seem to slip and then slam into gear, and a bunch of other crazy stuff that’s kind of hard to explain. I would blame it on the computer control but don’t know how to fix it. I was wondering how many of y’all are experiencing the same thing. Has anybody found a solution for this? I work my truck pretty hard on and off road and planning a supercharger install this winter. I would hate to toast another trans. I’ve also notice that there are a lot of shops building these things for hot rodded diesels. Does anybody know of a good shop that would build a gas version if I do have to get another one.
Old Jul 27, 2005 | 09:22 PM
99f350sd's Avatar
99f350sd
You maybe should get your computer reflashed and have a 4r100 expert check it out.
Old Jul 28, 2005 | 06:46 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
You can try www.atsdiesel.com they rebuild them for both gas ans diesel motors. They come with a 3 year 100K warranty, I haven't used one but a Friend of mine has so for he likes it.
Denny
Old Jul 28, 2005 | 08:35 AM
FortyFords's Avatar
FortyFords
Go to bts Transmissions(Brianstruckshop.com).Its the last tranny you will ever buy for your truck
Rich
Old Jul 28, 2005 | 01:31 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The tranny relies on the speed sensor on top of the rear diff housing, to tell when to shift...
Does your speedo bounce or is it off by a lot?
It's a known thing to see the speedo bang against 0 while driving and have the tranny shift all sorts of funky ways...
Old Jul 29, 2005 | 03:13 PM
penguin149's Avatar
penguin149
I understood that Brian's would only do diesel trannies. Something about the bolt pattern? My odometer showed 23,519 when my 4R100 bit the dust! Fortunately, I was under warranty; got the Ford rebuilt and it's been better ever since!
Good luck!
Jim
Old Jul 29, 2005 | 03:32 PM
Ponyracer's Avatar
Ponyracer
I would check out the MLP/TR sensor on the drivers side of the trans. If it has moisture in the connector then it is shorted out and could cause your shifting concerns and may or may not set codes. If it is the MLP/TR sensor, when you replace it add dielectric grease in the connector to water proof it!
Old Jul 29, 2005 | 05:00 PM
jokerforever
Thanks for the reply guys. This has been a problem since I bought the truck. The fact that I had the trans replaced and it didn’t change much leads me to believe that it is electrical. My speedometer doesn’t bounce around and, according to the speed checker sign things that the cops put up all over town, it’s right on the money. I’ll be under the truck tonight fixing a power steering leak so I’ll check the MLP/TR sensor. It is very possible there’s water in it because I not shy about dipping the truck in a mud puddle every now and then. Does anybody know of a “4R100 expert” in the Tampa Bay area that could check my PCM?
Old Jul 29, 2005 | 07:38 PM
Ponyracer's Avatar
Ponyracer
you can go to a parts store and have them check for codes. That is as good a PCM check as there is.
Old Jul 29, 2005 | 09:57 PM
jokerforever
That's the problem. I have a code reader and it isn't reading anything. I was hoping that I could find someone that could reprogram the "mystery box" and make it act a little better.
Old Jul 30, 2005 | 07:57 PM
jokerforever
Here’s something interesting. I remove my battery cables this morning while I worked on my steering. It was undone maybe four or five hours. After I finished and hooked the battery back up I went for a test drive. It was a different truck all together. It could be all in my head but I swear it drove better. I am a very aggressive driver, with a very heavy foot. Does the computer think it’s smarter than me and detuning itself as a protection means? Is OBD that smart? Like I said, I maybe imagining this. I’ll drive around for a little while and see if it changes. Please, feel free to make fun of me if I’m crazy.
Old Jul 30, 2005 | 08:50 PM
krewat's Avatar
krewat
Here's an opinion on this, doesn't mean nothin' just things I've heard here...
There have been certain posts where it seems the computer gets pigeon-holed, as in, it "adjusts" so far out of bounds that it's crazy ...
Some people with pinging V10's have reset their computer only to never have the problem again.
As a software weenie, I can see where yours may have gone in the opposite direction, and run like you have the crappiest gas known to mankind...
I can't imagine it affecting the tranny that much, but who knows... anything is possible.
As in anything Microsoft, always reboot before calling customer support
Old Jul 30, 2005 | 08:52 PM
Phinxter's Avatar
Phinxter
I'm not sure about Fords in general but some GM trannys have a shift learn procedure that can be performed if it shifts erratic. It requires a Tech 2 scan tool, and 30 minutes of driving. You might try calling up a dealer to see if this is the case with your truck if nobody can say if this is true about Ford trucks here. On the other hand if everything works ok and your happy with the way it shifts then don't worry about it.
Old Jul 30, 2005 | 10:16 PM
captchas's Avatar
captchas
Guest
you are not .its a good way to force the pcm to relearn how you drive, by pulling the battery leads off for a several hours or a overnight period it looses it's memory and and relearns how you drive. many of us do it as a every day thing when they act funkie.
Old Jul 31, 2005 | 12:50 AM
Ponyracer's Avatar
Ponyracer
alot of time it will take some driving cycles to get codes to come back and problems to resurface. If the trouble comes back with no check light flashing, check the MLP/TR sensor for moisture.
