Squeak in Back Breaks
Old Jul 27, 2005 | 06:35 PM
JohnAW's Avatar
JohnAW
Question Squeak in Back Breaks
I have a squeak in my back breaks or in the spantion or shocks. When I go to back up I hear a squeak not sure if it is my breaks but when I put them on when backing up it squeaks, or could it be my shocks?
Old Jul 27, 2005 | 06:48 PM
JohnAW's Avatar
JohnAW
I also need to tell you that my Ford Ranger is a 1999 with 76,000 miles on it it still has the organal breaks on the back. Also it has the shocks that it came with also.
If there is any other questions you would like to know please let me know.
Old Jul 27, 2005 | 07:42 PM
el conquistador's Avatar
el conquistador
for starters, take the back wheels and drums off and check the brakes and insides of the drums.
Old Jul 27, 2005 | 07:54 PM
JohnAW's Avatar
JohnAW
To come and think of it, if I am on a bumpy or uneven road you will hear it squeak also. I just cannot think where it is comming from and would like to get it fixed before winter comes.
Old Jul 27, 2005 | 10:32 PM
el conquistador
check all the bushings and look for loose bolts and what have you. could be the shocks, try bouncing the truck while it is parked to see if it bounces more than one or two times and see if it squeaks.
Old Jul 28, 2005 | 12:18 AM
JohnAW's Avatar
JohnAW
You brought up a good question here, never knew when to replace a shock. How many times should it bounce?
When should you replace a shock?
Old Jul 28, 2005 | 09:51 AM
el conquistador
many people say it should only bounce once or twice if it is still good. I tried this on my truck when the old shocks had about 150k miles on them and it only bounced once. The best thing to do would be taking one of the shocks off and seeing if you can compress it with your hands. you shouldnt be able to, but if you can then replace them.
Old Jul 29, 2005 | 08:01 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Spray some lube or WD40 all over the rear leaf springs, and the bushings where they bolt on.
If that fixes it then later on you may have to put regular grease at the tips of all the springs.
Good luck!
