primer
Old Jul 27, 2005 | 06:10 PM
rmalottwtes30's Avatar
rmalottwtes30
primer
I really cant decide what color to paint my truck, maybe white, its a 76 ford f100. Right now its just grey primer, is there a way to protect the primer so it dont fade or anything, maybe clear coating it?
Old Jul 31, 2005 | 09:20 PM
chrono4's Avatar
chrono4
dont clear coat it, as the primer is supposed to be rough when you paint so that the paint has somthing to grab onto. i would say leave it, but dont get it greasy or go to a hi po car wash. theres a camaro down the street flat black, and he went though the car wash the other day, and there swirls and big lines in it now.
Old Aug 1, 2005 | 12:24 AM
kenseth17's Avatar
kenseth17
You could clear coat it, and sand it later, but thats a lot of money to waste. Lacquer primer and urethane primers are porous and allow water to pass through. Could be bad if you have bodyfiller or baremetal under that primer. I would say sand the primer and spray a sealer or epoxy primer over it which is much better at preventing moisture through. Then later on you can either sand the epoxy and paint, or apply more primer or filler over the epoxy if needed. If you are going to paint the truck white, and probably will be painting over the epoxy primer, look for one in white which will be a nice color to paint over later with the white paint. 2 quarts should be plenty to put a good coat of epoxy on.
avf100
Sep 4, 2016 01:45 PM
Icicle
Paint & Bodywork
18
Oct 9, 2010 01:11 PM
sleep_deprived129
Paint & Bodywork
17
Feb 21, 2008 05:51 PM
CN Spots
Paint & Bodywork
Jun 10, 2007 09:20 PM
1978fordf250
Paint & Bodywork
Sep 15, 2006 06:25 PM
