Sponsored by: Real Truck
Fuel Gauge
Old Jul 27, 2005 | 05:49 PM
Pirate16's Avatar
Pirate16
Thumbs down Fuel Gauge
ok so i got gas today $60 bucks for 24 Gal, but anyway when i started the truck after fueling the gauge just returned to where it was before i got gas. i shut the truck off and then on again, no change. then as i am driving home i shut it off again, and back on still nothing. drove some more and the gauge is slowly moving up, it is back to a quarter tank after driving 10 min. so now it is slowly filling but still isn't showing full. anyone ever seen this before?? any help would be great. 04 250 5.4
Old Jul 27, 2005 | 05:53 PM
captchas's Avatar
captchas
Guest
this a common problem. let it sit over night and see how it reads in the am .it will for sure start reading better in a few hours.
always when filling make sure the motor and key are turned off .
Old Jul 27, 2005 | 05:54 PM
Pirate16's Avatar
Pirate16
thanks for the quick reply i will check in the morning. key and engine were off i had the key in my pocket.
Old Jul 27, 2005 | 06:20 PM
FortyFords's Avatar
FortyFords
Its the nature of the beast,the guage system uses a damping resistor in the instrumentation module to dampin fluctations in the fuel guage.
They do go bad,but as stated its been a noticable thing over the yrs of our trucks.
Rich
Old Jul 27, 2005 | 10:57 PM
2002 F350V10's Avatar
2002 F350V10
happened to me today
After I filled up today it took about 30 minutes for the gauge to eventually rise to the full level. Truck is an 02 with 20000 miles on it and a v10.Bill
Old Aug 15, 2005 | 07:46 AM
Hot Spot's Avatar
Hot Spot
I am having the SAME problem. It has been to the shop twice. First time they "PID" the gauge and checked for loose wires.
Last week I took it for the 35k service. They checked for loose wires, etc. Ended up draining the tank and replacing the sending unit.
My son took the truck on a trip this past weekend, same problem.
This started at about 28k mile. Very frustrating.
Has anyone got this fixed yet?
Old Aug 15, 2005 | 08:20 AM
Hot Spot's Avatar
Hot Spot
I searched through all of the archive threads on this topic and have not found a solution.
I always have the key "off" as stated in many posts.
I performed a TSB search and could not find anything on this. I did find an Oasis report that is very vague.
Any ideas?
Old Aug 19, 2005 | 06:17 PM
Apostle's Avatar
Apostle
Mine will do this once in awhile. It hasn't happen in two years though. I will shut it off, take the key out, and fill it. After starting it, the guage will stay where it was before I filled. A couple of years ago I was in the middle of North Dakota when it did it. I drove about 30 miles and it slowly creeped up to full. I never had the dealership look at it, because they are a bunch of boneheads there. I don't like them touching my truck. Its out of warranty now. Maybe I should of had it taken care of, but they probably would tell me nothing was wrong. It wouldn't do it when they looked at it. It would of been a waste of my time. As long as it runs good, I am not going to worry about it.
Old Aug 19, 2005 | 07:53 PM
utahtom's Avatar
utahtom
The key (pun intended) to avoiding this problem is to not leave the key in the auxilary position. Mine will always read low if I leave the stereo on while fueling. If your truck does it (frequently) without the key in the ignition, go back to the dealer (if under warranty). Better yet, put fuel in just prior to getting to the dealer and say: SEE...PROBLEM!
Old Aug 22, 2005 | 07:21 AM
Hot Spot's Avatar
Hot Spot
She is going in again tomorrow. The service rep said there is an "anti-slosh" circuit built-in to the instrument cluster that has probably "burned-out."
Makes sense to me based on what the gauge is doing.
This past weekend, we moved my baby girl into Western Carolina University. It is 285 miles from Sanford. The gauge seemed to be okay until I hit the mountain roads, up, down, twisting, etc. Then the gauge went crazy again. After sitting for a while, it fixed itself.
I got 21.4 going to WCU, and 22.5 coming home. This is my calculations, not the computer, although it was very close. I have never had a loaded 4X4 that got this kind of mileage, one of the many reasons, I LOVE MY Super Duty PSD!
I will post an update after the repair.
Old Aug 29, 2005 | 12:37 PM
Hot Spot's Avatar
Hot Spot
The problem was resolved by replacing the instrument cluster. Now after I fill up, turn the key on, the needle jumps up past full like it used to and the needle seems to be registering correctly as the fuel gets used.
Old Aug 29, 2005 | 01:41 PM
89LX306's Avatar
89LX306
Same here. My cluser was replaced on my 02 at around 24k miles. I now have 110,XXX miles on it and haven't had the problem since.
Old Aug 29, 2005 | 04:18 PM
mwpierson's Avatar
mwpierson
My 02 never worked consistantly enough to trust it. So, I always used the tripmeter to keep track of the mileage/remaining fuel. I still use this method with my 05. Just don't trust those guagues. Only problem with this is that you have to know what your average MPG is.
Mike
Old Sep 2, 2005 | 04:43 PM
Pirate16's Avatar
Pirate16
well i have fueled up 5 times since then and it was just fine, maybe the ignition was stuck in a middle position even though the key was in my pocket. so i will just go with it and see if it does it again.
Old Sep 2, 2005 | 07:36 PM
TDCSILVER1's Avatar
TDCSILVER1
I posted about this a while ago, when my 04 was still a baby, I had my feul pump replaced under warranty and it doesnt do it anymore. Sometimes mine would get an accurate reading but most of the time it read E. I had to guess how much gas i had for 2 weeks until i got it into the shop! Seems like every SD has a feul guage malfunction in some way or another, getting it fixed is tricky. I dont know much about the feul system, but they replaced my pump. It was 900$ but covered by warranty, my case may have been of the more severe though as it read empty most of the time!
