Sponsored by: Real Truck
abs or trans problem?
Old Jul 27, 2005 | 05:24 PM
amcomer17's Avatar
amcomer17
my 99' f-250 w/ v10 has the abs warn lite on and service soon lite on and the speed-o stoped working. truck runs fine for 10 miles or so and then all this happens. when this happens the trans shift hard like it has no vacaum
Old Jul 27, 2005 | 05:25 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 27, 2005 | 05:43 PM
Monsta's Avatar
Monsta
Sit. Stay.
Sounds like the VSS (Vehicle Speed Sensor) on top of the rear diff.
Simple, cheap swap.
Old Jul 27, 2005 | 05:48 PM
captchas's Avatar
captchas
Guest
try a fast one go to the top of the rear axle in the center is the vss that sends the speed signal to the speedo , engine and brakes. remove it ,"carefully" and clean it off of metal filing from the rear end . see if it works "your speedo" it's the most like colprete to your problems and will cause all your stated lights to come on.
have fun in FTE. i'm your moderator.
Old Jul 27, 2005 | 09:23 PM
FortyFords's Avatar
FortyFords
That be the fix (vss)
if it is covered in metal filings ,be sure to change your fluid and add proper amount of friction modifier if its a ls unit in the rear.
Rich
Old Jul 27, 2005 | 10:23 PM
krewat's Avatar
krewat
Yeah, what they said
