compression PSI
Old Jul 27, 2005 | 12:42 PM
bshackelford711's Avatar
bshackelford711
compression PSI
well i want to check my compression to make sure that everything is ok with my 390.
What are some ranges of the PSI i should get out of my 390?
Thanks
-Brandon-
Old Jul 27, 2005 | 12:52 PM
Freightrain's Avatar
Freightrain
New motor.....hmmm...maybe around 170 psi? Depends on how well the rings are seated, etc. Could be a bit higher. Just a shot in the dark. As long as all 8 are within close range of each other...you're good.
Old Jul 27, 2005 | 02:22 PM
Randyb12's Avatar
Randyb12
The main thing is that they are all within 20% of each other.
I would think anything over 100 psi and within the above memtioned 20% is ok.
