98 Ranger DriveShaft
Old Jul 27, 2005 | 12:32 PM
dell's Avatar
dell
I have a 98 Ranger automatic that seems to have drive shaft problems. I've taken the front driveshaft coupling off and coated the splines with teflon grease and it helps a lot!! But it only last maybe 3 to 6 months. Now the driveshaft is clunking again on take offs and I know its time to coated those blasted splines again and I also need to replace the rubber boot. Does anyone know there is a better way to fix this problem ? Has Ford came up with a better idea on this issue or am I domed to crawl back under the darn thing and grease it again?
Old Jul 27, 2005 | 04:23 PM
RangerRuss's Avatar
RangerRuss
Dell:
Here's the scoop on the driveshaft clunk:
https://www.ford-trucks.com/forums/s...hreadid=109423.
In one of Rockledge' responses, there is a "link" titled "Driveshaft Lube". Good one to read and understand.
Hope this helps you.
Russ
96f150
1997 - 2003 F150
Oct 19, 2011 11:37 PM
wgotthardt
1997 - 2003 F150
17
Jan 10, 2008 05:31 PM
wresleu
1997 - 2003 F150
May 28, 2006 11:45 PM
FX4dude
2004 - 2008 F150
Apr 4, 2006 07:27 AM
ar15sr
Mar 24, 2003 12:11 PM
