9 inch rearend
Old Nov 20, 2002 | 12:21 AM
Umpqua Arms's Avatar
Umpqua Arms
9 inch rearend
got a question. Are all nine inch rear ends the same? Heres what i mean. took the rearend off my 79 f-150 and took out the third member when i went to get a gasket the parts guy told me the 10 bolt pattern matched up with a 70 something ranchero. I realized they made different widths but assumed the third members were all the same. My mistake or his? I knew someone had changed the gearing in the rear to 4.56 but apparently maybe the whole thing as well. If so any other oddball features i need to know about. Any help appreciated. Thanks
Old Nov 20, 2002 | 12:27 AM
Superdave's Avatar
Superdave
9 inch rearend
To the best of my knowledge, it was his mistake.
Old Nov 20, 2002 | 12:31 AM
banjopicker66's Avatar
banjopicker66
9 inch rearend
[updated:LAST EDITED ON 20-Nov-02 AT 01:46 AM (EST)]Here are some links which might help you:
http://www.kevinstang.com/Ninecase.htm
http://www.ridgenet.net/~biesiade/Fordrears.html
Old Nov 20, 2002 | 12:48 AM
Mil1ion's Avatar
Mil1ion
9 inch rearend
This is the 73-79 forum.
Here are a couple more links.
http://hiqties.hypermart.net/9inch.html
Dennis
F.T.E. Assistant Administrator
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 20, 2002 | 12:54 AM
BULGOD's Avatar
BULGOD
9 inch rearend
Old Nov 20, 2002 | 10:00 AM
hawkrod's Avatar
hawkrod
9 inch rearend
[updated:LAST EDITED ON 20-Nov-02 AT 11:02 AM (EST)]all 9 inch rearends since 1957 take the same gasket. so he was right, a 70 something ranchero gasket will fit a 79 ford truck. now that being said, there are two different gaskets on the market. one has two notches on the inner edge so it can also be used with a 9 3/8 rear end. on a 9 inch either one is fine but the 9 3/8 requires the two notches to clear the ring gear (yes, you can just trim the gasket to fit). hawkrod
