Bad news for shuttle, AGAIN!!!
Well, its bad news for the poor guys and girls in the shuttle Discovery. MORE stuff hit the shuttle and a heat tile came off. Also heard a bird hit the rocket on lift off. I hope to god that they can fix the problem and get everyone back safe.
I hadn't heard any of that. Hope it's not as bad as it sounds.
edit...just checked Foxnews.com. The tile that was damaged was a belly tile. Thankfully, not nearly as serious as the tiles lost on the Columbia. The belly, being flat and not directly in the way of heat friction from re-entry, won't be in as much danger of critical failure as the tiles on the leading edge of Columbia's wing.
Rob.
Rob.
Each title is fit to one spot only, they are highly individualized, the problem they had yesterday will not affect this flight at all, the biggest concern on all flights is of course the leading edge from strikes, and the leading area on the nose gear door, that is of utmost concern and that area is OK
I had heard that some of them were damaged beforehand for the sake of practicing repair also. I'm not entirely sure. I tried watching it on space.com and it didn't work. Nuts to this computer.
A team has been working on several different ideas to replace/repair any tiles damaged during liftoff or hit with other "flying space stuff".
I watched a special on Discovery or some other channel about the ideas and it looked like they were very close to a viable solution to any tile problem that might come up. I'm sure that there was a procedure implimented before the shuttle ever got close to the launchpad.
Here's a link that provides more information...the last section on repairs.
http://www.technologyreview.com/articles/05/07/wo/wo_071305brown.asp?p=0
hers some info on the tile that came off during launch: http://www.comcast.net/news/index.js...27/188496.html
I read somewhere that if the orbiter sustains enough damage that it can not return to earth safely that there is a second shuttle that can "go get 'um" at the space station.
Nice to have contingencies.
Russ
Russ
they are getting Atlantis ready to go, not necessarily just for rescue, they have a serious backlog of missions to do. When the leading edge on Columbia was damaged, i don't believe any structural metal went, but it wouldn't have to, because if the heat tile was damaged and the extreme heat of reentry was able to get past it, might as well take a plasma cutter to the metal because that would be the same effect.
