another cam ?
Old Jul 26, 2005 | 09:46 PM
good 'ol ford's Avatar
good 'ol ford
another cam ?
hey has ne one used the summit duel patter cam here are the specs
Operating RPM Range: 1,500-4,000 RPM
Intake Duration 050 inch Lift: 204
Exhaust Duration 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 272
Advertised Duration: 262 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.484
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510
Valve Lift with Factory Rocker Arm Ratio: 0.484 int./0.510 exh. lift
Lobe Separation (degrees): 112
im looking to build a daily driver with plenty of umphh and decent gas milage the only thing that worries me is the low rpm range of the cam i was looking for more 4500-5000 but idk. more just looking for some input and to see if neone has ever used this cam
Old Jul 27, 2005 | 10:13 AM
53fatfndr's Avatar
53fatfndr
I've seen a few posts here and there where people have used the Summit cam. Most seemed to be pleased with it. Just looking at the cam profile, it resembles the Edelbrock performance cam profile........could be the same one. Compare the two and see what differences there are.
