Can anyone shed some light on bump steer? It seems my truck has slowly developed this problem over the last couple months. It didnt do it when i first lifted the truck, now it has slight bump steer (or is this normal).
Also, steering wander has progressive been getting worse when on the freeway at speed.
Is it the ball joints, tie rods....i dunno. Thanks.
Check you Steering Stabilizer.
Mine was worn out and it made the truck vear on the HWY when hit a chuck hole Ect, after removing the stock Stabilizer let it sit for a when then run it though a full stroke and see if there is a dead spot in it at least that what mine did I replaced it with a aftermarket it made all the diffrents.
