Blue Engine Smoke-funny air filter
I've used a bellows type electric fuel pump (AC brand) to remove the last bit of fuel.
Cheap (50 cents a bottle) rubbing alcohol works fine for locking up water.
Is there a lot of sludge on the bottom of the oil fill cap? Before you change the oil add a quart of M.M.O. or ATF to the engine oil. Let the motor go through a few thermal cycles, drain while it's still HOT. Don't be surprised if you have to replace those 12 year old gaskets and seals.
On using a shop vac: The results were best expressed by a pretty little thing in a great movie when she said; "Baaaada boom, -big baada boom!"
