pump bleeding
Old Nov 22, 2002 | 11:39 AM
Mark47025's Avatar
Mark47025
pump bleeding
hey guys hows it going i was just wanting to know if thear is any way to bleed the power steering pump other than turning the wheel from side to side thanks fore anyones help mark
Old Nov 22, 2002 | 12:52 PM
loudfords's Avatar
loudfords
pump bleeding
Old Nov 22, 2002 | 04:56 PM
woppini's Avatar
woppini
pump bleeding
get the wheels off the ground first, then you can go from side to side. Overnight, keep the cap off so the air from the foam can escape. Ford pumps can be a pain to bleed sometimes
Old Nov 22, 2002 | 06:26 PM
theonlybull's Avatar
theonlybull
pump bleeding
add fluid, drive it, add fluid, drive it, add fluid, drive it, add fluid, drive it..... at somepoint, it will stay full.....
