Electric fan current draw?
Old Jul 25, 2005 | 11:04 PM
Cranky's Avatar
Cranky
Question Electric fan current draw?
I have a two speed electric fan on my '75 E-150. It came from
a Ford Tourus.
Does anyone know how much current it should pull on high speed?
Thanks,
Bob
Old Jul 26, 2005 | 12:37 AM
yozsi's Avatar
yozsi
probably around 12-15 amps rms and about 30 amps peak. all with good wiring and connections.
Old Jul 26, 2005 | 09:18 AM
84-250's Avatar
84-250
i got a 2 speed fan from a mercury tracer. on high speed, the startup current is 100a and the run current is 25a.
Old Jul 26, 2005 | 06:00 PM
Cranky's Avatar
Cranky
Thanks guys, after installing factory air in my old van the taurus fan worked fine exept
my alternator couldn't keep up, so I put a 100 amp alternator on. That worked real well,
but it seems that now with plenty of power available the fan was able to pull enough to
blow the 30 amp fuse. AC works great though (BIG JOB).
Thanks again,
Cranky
Old Jul 27, 2005 | 12:41 AM
optikal illushun's Avatar
optikal illushun
start up is 100A and contunious is like 33A.
Old Jul 28, 2005 | 02:14 AM
Jefftopgun's Avatar
Jefftopgun
I got one on ebay a while back, it was supposed to be ford stock from some vehichle, came with a little box that clips into the fans electrical posts, 1 for ground, but then 1 with a 20 AMP resistor and then other a 40. I have the 40 hooked up to a switch I bought from autozone rated at 50AMPS, but it keeps blowing the switches after about 2-3 months of regular use ( i e maybe 2 or 3 flips a day). But I can sit in the driveway and rev 2500ish RPMS, and it will still drop my coolant temp quite quickly hehe, love the fan, love the motor more!
