how much compression for stock starter?
Old Jul 25, 2005 | 08:19 PM
hatemakings/n's Avatar
hatemakings/n
How much compression can the stock starter handle before you have to upgrade? Do I just throw the stock one on and see if it will crank and if it does then I'm ok?
Old Jul 25, 2005 | 08:22 PM
rusty70f100's Avatar
rusty70f100
Yeah just throw the stock one on. It's not how much compression you have, it's how much cylinder pressure you build when cranking. The cam has a lot to do with this. You could build a 10:1 motor that would crank over nice and fast with a big cam, but would crank over slow with a small mileage type cam.
Old Jul 25, 2005 | 08:28 PM
hatemakings/n
Ok so it's safe to say that just because I have 8.5:1 doesn't mean my starter can handle it? I set my timing to were the motor runs really great and no appearent pop through the carb but it slowly cranks and won't start when I shut it off. Am I building too much cylinder pressure? Is that bad?
Old Jul 25, 2005 | 09:13 PM
rusty70f100
At 8.5:1, you'd need a REALLY small cam to make the stock starter not handle it. I'm talking, like, 2 sizes smaller than stock. Timing can make it crank slow, if the timing is advanced far enough. Where do you have yours set?
Right now, I'm kinda thinking your starter is worn out. How are all the electrical connections to it? A loose connection can make it crank slowly, or not at all in some cases.
Old Jul 25, 2005 | 09:26 PM
hatemakings/n
I set the timing at 10* but with the carb making a slight pop at that setting I'm begining to think my marks are off. It was a recon crate short block so I wouldn't put it past them to run a really small cam. The connections are good but the starter is almost 2 years old.
Old Jul 26, 2005 | 05:13 PM
rusty70f100
They probably use a reproduction stock spec cam. To check the timing marks, find TDC on number 1, then compare it to the location on the damper. If it's off, it is likely that the damper slipped, in which case you should get a new one.
Old Aug 24, 2005 | 11:09 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds like you have the initial timing too far advanced. Does it do the "whir whir whir" thing?
Once the engine is hot, the rings seal REALLY well, and the starter can't get past the point where the spark plug fires.
wyckedcombo17
Sep 10, 2013 04:46 PM
DJOHNSTON78
Flathead V8 & Flathead 6
Oct 15, 2008 08:41 PM
Youngen69
Apr 19, 2005 09:04 AM
Ray71
Jun 20, 2004 06:15 AM
stryder
Aug 18, 2003 07:39 AM
