2003 Explorer not blowing air
Old Jul 25, 2005 | 03:32 PM
mjfitting's Avatar
mjfitting
My wife has 2003 explorer, and lately the blower is not pushing the air it was. The air is still cold but you have to set the fan at high almost to get air flow. What could this be?
Old Jul 27, 2005 | 06:27 AM
don96exp's Avatar
don96exp
Couple of things come to mind, can you hear thblower motor at all fan speed settings? I'm not sure if Ford uses relays or a blower resister to control blower motor speed. If the blower motor works in all settings then it could be an air distribution problem, does the '03 have a cabin air filter? Look in the manual and if it does remove it and check the air flow. does the air discharge from the defroster and / or floor when in AC mode? Do you have good air flow when in heat or defrost mode?
Old Jul 27, 2005 | 02:53 PM
87 XLT's Avatar
87 XLT
DOn pretty much covered it all. Like he sez you need to know how the blower speed is controlled. Take a look at a wiring diagram.
If it's wired the same as a 97 it has a blower resistor that controls only the lower fan speeds.
bhelton26
Feb 1, 2016 10:28 AM
IIGood
Jan 21, 2016 06:12 PM
bmuhlbach
Sep 21, 2015 09:02 PM
golfdrinker
Nov 13, 2007 11:03 AM
general124
Apr 19, 2004 08:40 AM
